andyj
There's no F in Quality..
IIRC the Ibiza Cupra R hoses I bought direct from Goodrich direct were about 485mm in length.....
107cm is MASSIVE.....
No idea how you tighten up a bolt with no way to stop it turning![]()
how are you stopping the driveshaft from rotating when tightening the hub nut ??
easiest way is to do the hub nut as tight as possible with the car jacked up and the wheel off, and then to fit the wheel (without the centre cap in) and then lower the car onto the ground, you should then be able to tighten then up real tight![]()
i think its about 150lb ft, its a 'kin lot and you need a serious bar/extension set up to do it, its in the haynes and RobT knows it off by heart as im usually stood on his brake pedal when he does it!
