Good luck, should easily get that lot done (just take care when putting the hub nut back on that you don't slip it & round the nut)
Plan for Sunday is then to get the driveshafts, hubs, and front coilovers ( assuming I can get the old top mount bolts undone ) on the car so she can sit on 4 wheels again. Then I'm just two caliper brackets and some brake hoses away from having a drivable car again
The plans have changed brake wise, I've picked up a set of Leon Cupra R brembo brakes at a nice price so they're going on now
Hopefully I'll get my polishing kit soon as well so I can have a go at polishing out the salt damage on the TT comps and get them blinging again
Weather is looking good so far too...
I'll try and post some pics up on Sunday once she's sitting at a sensible height
Pete
I dont recall OEM ones being that phat, have you the ld ones to compare with?
Could you undo the small jubilee click and pull them further down the drive shaft, stretching the boot longer? Bit of a bodge, but...
