Forge DV failed!
Big_daddy
Going going gone.....
Oct 20, 2006
3,930
Brummy
Cuming back from town this morning! The car was driving normal. i gave it abit of gas then heard a odd sound from the dv, it normally makes a whoosh sound but it turned into a quick chatter sound.
On the boost gauge it dropped pressure fomr -0.8 to -0.2. The car was not shifting and pick was very poor!
come home and examied all the pipe work and check the dv!
Forge 007pa
[/IMG]
It was total shattered! The bottem end was missing!
Lucky i had spare diahpram for it!
Wat annoys me is i paid so much as its more reilable and can handle higher pressure!
Im NOW worried :( , the small bit of plastic of the diagpram has got sucked into the intake system. [:@]
I cant see it! will this mess up the turbo???
RikH
Texas Cowboy
Oct 17, 2005
2,474
Yorkshire
something so small is unlikely to cause a big turbo issue id say
id personally ring forge asap and show them your picture etc and see what they suggest
RobM
Back from the dead...
Sep 27, 2006
4,982
Southampton
Even a tiny object getting caught in the air intake system can cause huge problems with the turbo. I'm not sure how possible it is to get as far as the turbo, but I'd be worried personally.
Big_daddy
Oct 20, 2006
3,930
Brummy
This what forge emailed me saying:
Hi Atif
Sorry that you have had an issues with this diaphragm , I believe that this is an isolated incident .and everything should be fine .
Tell you what I'm going to do if its ok with you , Ill send you our 007P piston type valve out as a replacement free of charge, and then I can have yours back for evaluation
We have actually stopped making the diaphragm valves now ....not be cause of any problems with them but due to the fact that sales have been very slow and many customers prefer the piston , Please let me know if this is ok
regards
Peter
Peter Miles
Forge Motorsport
www.forgemotorsport.co.uk
www.forgemotorsport.com (USA)
E mail [email protected]
Tel 01452 380999
Fax 01452 386333
Big_daddy
Oct 20, 2006
3,930
Brummy
Im woried NOW :cry: :cry: :cry:
samm little thing! Guna cost me big bucks!!! :headhurt:
dmmsta
Sold car - bought bike
Feb 10, 2007
787
Maidstone - Kent
Being completely unqualified, and not knowing anything about internals i'd say that if it was going to cause problems it will prob have done so already...with the turbo sucking the air from the intake any particals will have already gone into the system...
Like I said have no knowledge of exactly how it works, but that would seem logical in my brain???
RobM
Sep 27, 2006
4,982
Southampton
You're totally right.... especially if Big Lad put his foot down a fair bit after it failed. But that plastic has to have gone somewhere, and that's what would worry me. Even grit or sand or something that small can kill a turbo, so big-ish lumps of plastic would be catastrophic.
Big_daddy
Oct 20, 2006
3,930
Brummy
when the boost gauge droped and the dv changed sound (sounded quite nice ;) ) i did rev it! restarted the engine. abit of stick!
the car drives normal now! Just wondering where it could be by now! its is plastic after all and could have melted by now!
Im happy forge are sending me a alternative replacement as i dont have to worries of it failing espically when im in the middle of no were! :clap:
NotApplicable
There's a big difference between grit and a bit of plastic. Grit can get where you don't want it to and ruin a bearing. A large piece of plastic might shatter into bits large enough to not get into any unwanted place but large enough to be blown into the engine. I would hazard a guess that any plastic in the combustion chamber would get burnt up on the first time around and exhausted as noxious gases.
Just a guess though based on science of materials...
NotApplicable
Just out of curiousity, was there any problem that fitting the Forge DV fixed?
I've been having occasions when the boost seems to be vented by the ECU unneccessarily. I was wondering whether a better DV (than standard) would be a good thing to fit.
Ruddmeister
Everything in Moderation
Jun 23, 2003
8,218
Weston-super-Mare
en.wikipedia.org
We know the standard Bosch unit is unreliable at std pressures, it's cheap plastic cr@p, my OEM Bosch unit went on my old LCR after about 7,000miles.........i'd replace it on a remappped motor for peace of mind.
You can do a leak test on your DV details in Forge's section somewhere if you search
Big_daddy
Oct 20, 2006
3,930
Brummy
That'll have gone straight into the compressor blades of the turbo and been shredded.
I wouldn't lose any sleep over it now. It'll be ok.:)
Thank god for that! Just gona take easy till i get the new DV! The 007p has metal piston so it should be stronger! but mines cost 10 quid more (must be roatating vacum line thingy). :blink:
