superleggera wheels and scrubage
Forbez
Huge Member!
Feb 11, 2004
5,878
S.Wales
Visit site
hadz
286
West Sussex
right sorry bout the slow reply! i guess you lot want to know what tyres i have got???? I have got toyo proxes T1 and they are 205! I have been back out there today and raised it up quite alot and the back still catchs when on a bumpy road and the fronts still scrub and the lump of plastic on the arch liner! i havent got a clue what to do now! any ideas?
ibizacupra
Jack-RIP my little Friend
Jul 25, 2001
31,333
19
glos.uk
can you see where exactly the rubbing is going on?
rear/front, inner/outer arch, front/rear of said arch etc?
hadz
286
West Sussex
yeah the front is rubbing on a small bubble shop bit of plastic on the inside of the front arch, this is catchin on both sides , as for the rear i think is catching the outside of the arch! do u think it could be down to the tyres then?
ibizacupra
Jul 25, 2001
31,333
19
glos.uk
i am surprised... i ran 7.5x16 wheels/tyres with 215-40-16 T1S rubber -50mm lower on ET35 with 15mm rear spacers too... front rubbage I had but that goes after a while :rolleyes: ;)
hadz
286
West Sussex
Im havent got a clue what to do now? shall i try the wheels with different tyres or just keep raising the coilovers up till they stop the rubbing! i dont think that its goin to stop the scrubbing on the front tho , it seems to be down to the width of the tyre!
any ideas?
Tom B
4,710
16
Northampton
try trimming 1st.... removing ends up coating the engine bay in crap
no point rolling the arches, with properly aligned wheels on 6-7J wheels you should be miles away
D'oh! I ripped em out a couple of hours ago.
I'm running 6x16" 20vT wheels now and they still rub! Alignment is the next job...
Nov 2, 2004
9,335
South Wales
I bet your down too low. Mine used to do it when i first put my coilys on but now its set at a proper height.
You go down that low and you've gotta expect problems.
hadz
286
West Sussex
PhilW - how low have u got urs at the mo? have u got a pic that u could post up please? did urs used to rub on the same bit?
Nov 2, 2004
9,335
South Wales
I've got 15mm spacers so i had to raise it, but yeah it rubbed on that bit on the front arch on lock.
Raised it a bit more since this pic as well.
hadz
286
West Sussex
that looks really goot phil! i dont spose u know how low it is do you so i can adjust mine the same? it takes so long to jack it up adjust it and then test it again! What spacers u got on urs?
Craig!
IHI Ibiza Cupra
Jan 6, 2005
1,876
Guisborough
www.vagcars.co.uk
Another thing is camber, if you've got positive on the front it'll be very close to the arch. I've found that out before after fitting suspension and the wheels back on then taking it to be tracked up.
MR Ibiza Cupra
185
London
Camber on the front is a possibility as craig said.... but the rear hmmmm cos camber on the rear cant be adjusted. The lower it is at the rear the more negative it gets.:confused:
hadz
286
West Sussex
thanks for all the help lads! i have been out there again 2night and raised it up a bit more and it seems to have stop the scrubbing thank god! i will take ur advace and go and get it tracked and the camber adjusted now! i will have to post some pics up next!
