Just another update and some new pics for you guys, I went out today to tidy up the wiring and give the ballasts a better fix.
I couldn't find anywhere to mount the ballasts securely so I found a couple of flat surfaces, gave them a good clean and fixed them in with Velcro... I applied the Velcro to both the surfaces and ballasts, I left them like that for half an hour so that they stuck well before fixing them together... I also fitted my chrome grill at the same time.
Anyways, hopefully these pics are a little bit better now you can see.
Pic One - This shows the 25mm holes I cut on the light covers.
Pic Two - The offside headlamp, plenty clearance for the bulb, no need to remove the reflector.
Pic Three - Same again though the nearside.
Pic Four - Shows where the offside ballast will be located.
Pic Five - Showing where the nearside ballast will be located.
Pic Six - Velcro applied to offside ballast.
Pic Seven - Velcro applied to nearside ballast.
Pic Eight - Offside ballast now secured in place, wiring cable tied together so it can't catch the utility belt.
Pic Nine - Nearside ballast in place and wiring tied together.
Pic Ten - A pic of the HID's after warming up for a minute, maybe a little blue as they are still brand new.
Hopefully this helps!
