Will these fit LCR??? and Opinions...
karlosR
TORQUEY, NOISEY V6
Mar 10, 2006
1,469
BEDFORD
if i had the money i'd have these
RickC
BUILT NOT BOUGHT
Dec 23, 2004
1,621
Lincoln
wheels with a lip on wont fit lcr unless you want your wheels to stick out 3 inches past your arch
MEXCUPRAR
Newbie
Mar 15, 2006
79
okok
ok so what would I need to do to fit these on the LCR? and what is the difference in bolt pattern mean lcr is 5x100 or112? and this one is 5x114.3 meaning what???:cartman:
Nov 27, 2006
1,204
www.cardomain.com
BBS RS-GT
VW sell these for the MkIV Anniversary Ed.
There's a new set on eBay if you've got a grand burning a hole in your pocket
Y'know how you've got 5 bolts holding the wheel on ? Well if you draw a circle through the centre of each bolt hole, the pitch on the LCR is 100mm (PitchCircleDiameter)
Bigger Audis and the newest SEATs in the range have the holes slightly further apart (112mm) and different manufacturers tend to have specific sizes that they use for their range of cars (or vans/trucks)
It may be possible to get the wheels to bolt on using re-bolt spacers - discs that bolt to the hub and the wheels bolt into a 2nd set of holes in the disc - but they're thick, and as mentioned above, to clear the brakes they'll stick out of the arches by miles :(
Ruddmeister
Everything in Moderation
Jun 23, 2003
8,218
Weston-super-Mare
en.wikipedia.org
To give people an Idea I used 10mm spacers and 8inch wheels and they were flush with the arch's pretty sure they were an ET35 off set but i'd need to check that off set......oh and I had a good 3-5mm clearanace on the caliper
MEXCUPRAR
Newbie
Mar 15, 2006
79
Thanks guys!
Too bad I would've loved to see those rims on her even called the states to see if the had them in 5*100 but the were like 'smaller european cars blah blah blah'
