It's just the added cost of a smoke test iv just spent over a grand in the last month! Ill run again after the repair on the valve and see of it comes up again then ill know if that was the cause ! I'm prob goin to strt replacing some of the hoses soon anyway
so you would rather replace random pipes, costing you money, than find exactly which pipes are leaking via smoke test?
Really?
Don't they also say that a good indication of boost leak is what psi it settles at when idle? Mine sits at 22psi which I thought was right! I just want to try and solve it without chucking too much money at it! I may do the catch can regardless to be honest but obviously want to find the issue first! Is there a way I can put I monometer on one of the smaller pipes as I'm a gas fitter so that would show if there is pressure loss? Iv seen the kits that you put on the charge pipe hose and was just wondering if I could do a test that way?
