Not a direct fit.
You'd need a downpipe or pro imports up-pipe, turbo to charge pipe hose and TIP just to make it fit.
Then injectors, 3" maf and a map to make it run.
k04-001 is basically a k03sIsnt the k04-001 a direct replacement for the k03 but there abit unreliable
im sure alex from tts has one on his
The K03S turbo is the same as the turbo fitted to 180 BHP leons and Golfs. This turbo will fit in place of a K03 no problem.
The K03 to K04 internal upgrade turbo is different. It has the internals of the K04 but the connections to fit in place of a K03. You dont need to change the pipework.
K03S £399 plus VAt
K03 to K04 upgrade £699 plus VAT.
Both turbos are brand new with no exchange required, in stock and the price includes next working day delivery.
Best Regards
Mark
Backdraft Motorsport.
The K03 to K04 upgrade turbo is designed and built at the Borg Warner factory. So it is an official turbo not something that is put together in someones shed.
The part we supply is a complete brand new turbo. It is designed to replace the standard K03 so you dont have to replace the pipework. You will need gaskets, copper washers and studs.
It is basically a K03 housing with K04 internals. There is more to it than that but thats just the best way to explain it.
Bets Regards
Mark
01908 821216
Bets Regards
Mark
01908 821216
