will a k04 turbo fit my seat ibiza cupra
thewiizard
Tarmac Tantaliser
Jan 15, 2007
486
Rugby, Midlands
www.tbfh.org
Its a K04, 300BHP max I would reckon..
If I am not mistaken, the K04 is the same turbs they plant into the 225bhp motors and they're almost if not exactly the same engine as most of us on here, so in theory a remap would hit that to 260+ at least as standard.
Obviously you'd need the higher rate injectors, high powered fuel pump, DP etc
What interests me is the turbo they fit to the new Leon FR, 244bhp?
May 2, 2006
2,758
from 260 to 280 are figures you will reach from a standard k04 imo
the k03s with k04 internals sounds VERY similar to the turbo i run that backdraft are on about
speedy_666
28
if i had the backdraft k03 with k04 internals, what injectors and fuel pump and down pipe, also how much and where can i get these from,
and would my standed engine take 280bhp without blowing it up?
May 2, 2006
2,758
stock fuel pump will be fine, if you want piece of mind throw in the BAM fuel pump
i used 440's injectors under the instructions that my mapper wanted these to map too. LCR injectors will be fine though - engine wise, it wont blow at that level unless your producing silly boost out of your turbo
