will a k04 turbo fit my seat ibiza cupra
Nov 2, 2004
9,335
South Wales
Not a direct fit.
You'd need a downpipe or pro imports up-pipe, turbo to charge pipe hose and TIP just to make it fit.
Then injectors, 3" maf and a map to make it run.
thewiizard
Tarmac Tantaliser
Jan 15, 2007
486
Rugby, Midlands
www.tbfh.org
Not a direct fit.
That's basically it.
The downpipe apart from the actual turbo and TIP removal/fitting would be the most knuckle bashing, everything else is top side and a piece of piss to do.
Its worthwhile doing the downpipe even for the KO3s
Backdraft
K03 to k04
The K03S turbo is the same as the turbo fitted to 180 BHP leons and Golfs. This turbo will fit in place of a K03 no problem.
The K03 to K04 internal upgrade turbo is different. It has the internals of the K04 but the connections to fit in place of a K03. You dont need to change the pipework.
K03S £399 plus VAt
K03 to K04 upgrade £699 plus VAT.
Both turbos are brand new with no exchange required, in stock and the price includes next working day delivery.
Best Regards
Mark
Backdraft Motorsport.
jonesya3
603
Liverpool
K03S £399 plus VAt
Best Regards
Mark
what does the k03 to k04 upgrade include please mark
Backdraft
The K03 to K04 upgrade turbo is designed and built at the Borg Warner factory. So it is an official turbo not something that is put together in someones shed.
The part we supply is a complete brand new turbo. It is designed to replace the standard K03 so you dont have to replace the pipework. You will need gaskets, copper washers and studs.
It is basically a K03 housing with K04 internals. There is more to it than that but thats just the best way to explain it.
Bets Regards
Mark
01908 821216
jonesya3
603
Liverpool
Bets Regards
Mark
01908 821216
Sounds good what sort of bhp you looking at plus will any other parts need upgrading i.e 3 inch maf, larger injectors, larger tip ?
any exchange on those aswell for my old k03
Myki da Pyki
Senior Member
Jul 15, 2007
3,302
Bristol
www.facebook.com
Bets Regards
Mark
01908 821216
What kind of power are we likely to see from this?
