Which Dump valve?
Beaker™
Slightly Unhinged........
Nov 21, 2005
1,900
C:\UK\Glos
Enclosed will always be better as the engine is always producing heat. But your less likely to experience any major heatsoak this time of year.
Beaker™
Nov 21, 2005
1,900
C:\UK\Glos
Mine suffers from heatsoak in the summer when fitted with an open cone, probably due to the SMIC not bein able to cool the hot air thats drawn in by the open filter. If your taking in hot air from the engine bay you'll be relying more on your IC to cool the air, and if its not up to the job you'll get heatsoak.
Nov 2, 2004
9,335
South Wales
I very much doubt a couple of degrees more goin down your TIP will cause heatsoak as your turbo runs at silly temps, which then relies on your cooler to drop the charge temps.
Your IAT is on your manifold, which is after your turbo and after your IC so a couple more degrees goin down the TIP wont effect a thing.
Now running a side mount or crap IC will effect more on your heatsoak.
Ambient temps are up in summer anyway so your engine will run hotter as a result.
jacko1988
clip plz! see im trying to figure out what is the best combo in terms of sound and performance, coz ive heard for performance its best to keep the standard airbox and smooth it out with a green panel filter. so i guess if you have that then you are gonna need a deeper and louder sounding dump value?? (new to all this and trying to learn as much as poss. lol)
