where do you plumb your catch tank into
p34ch3y
tastefully modified
Oct 17, 2005
2,879
cambs
just got my longer bit of pipe to put on the breather side of the catch tank,i have stuck it down the driver side wing,befor when you stoped you could realy smell it so hopefully now its down the wing i wont be able to smell it as much failing that i may relocate it behind the engine out under the back
would it be a bad idear if i stuck the mushroom thing on the breather pipe of the catch tank then into the tip, or should i just leave it how it is now
Nov 2, 2004
9,335
South Wales
You can have it go back to the tip like it was previously, but then theres not much point of a catch tank. I'd bin the mushroom valve, blank the tip and drop the pip down into the wing without a breather filter.
Keep an eye on the catch tank level as it fills up pretty quick.
p34ch3y
tastefully modified
Oct 17, 2005
2,879
cambs
yea thats how mine is set up at the mo!
did you notice any changes to performance or sound well anything realy when you done it?
p34ch3y
tastefully modified
Oct 17, 2005
2,879
cambs
well emptyed my catch tank for the 1st time last night god dam they do fill up quick,this is how much it filled up scince the begining of this thread
dos this all look ok, im abit concerned about how quick it fill up and what its cought, it pritty much just water mixed with a tiny bit of oil
is it all ok
p34ch3y
tastefully modified
Oct 17, 2005
2,879
cambs
true true
guna put some kind of quick release drain plug on it so i dont have to keep takeing it in and out to empty it
v-g
is an alien.
Mar 10, 2004
938
Nowhere near, i.e. Norway.
That looks not good to me! :p (Who am I to speak about this, I don't even have it plumbed in right.)
Where exactly does all this goo go when a catch tank is not present?
Nov 2, 2004
9,335
South Wales
Either into your turbo inlet or inlet manifold.
And people worry about a little amount of oil in an air filter!
Mine is off a 25-22m conenctor jammed into the hard plastic elbow off the oil filter housing.
