Dont sweat it bro happens to everyone! Take solace in that person is likely leading a miserable life lolI realise the risk I took going through bank transfer. I accepted that risk. I’m just a trusting person
I am and on a LOT of groups so curious to hear who the little thieving fvcker is?I am not on Facebook. But name and shame them. It will help others avoid him too
Ah right, just wanted to know as swapping out the glass for polycarbonate at some point so didn't know if the alarm needs to get a response from the motors which I plan to remove as well as the wiring (cuz road going track car)The windows aren't coded in. Why do you want to deactivate them anyway?
If you don't want them to work simply unplug the individual motors on the regulator panels.
Also, you do realise that you can isolate the rear window switches from drivers door switch don't you?
If it's the original locking bolt then you can usually get them off by whacking a 20mm socket over the top of it.Realised today I’ve lost my locking wheel nut. **** the bed what a pants week
If it's the original locking bolt then you can usually get them off by whacking a 20mm socket over the top if it.
Sent from my SM-G986B using Tapatalk
Can you post a pic of your locking wheel nut?
Ive got a few l/w nut sockets in my toolbox. You never know, one may fit or be enough to undo them.
Pm me an image if you like.
Sounds like a standard one, I've taken loads off breakers over the years using the 20mm socket technique or the other way o do them is by using my specifically sanded down 1/2" extension bar which I drive into the splines when the bolts are really tight.I think it has ten splines. I’m not too sure
Yeah there are several types, even some have the same amount of spines but at different pitches so still won't work.Yes mate as long as it’s got ten splines. I’ve seen they come in many types
Whilst i was out there ive taken a pic of the coin tray in my car. Its split.
Been looking for one for ages but havnt seen another.
Is tps the answer?
