Rich.T
1,609
932
Just a trip to the hand car wash after work.
But tomorrow i will mostly be doing an emissions test on my car under mot conditions to see how the new 200 cell sports cat holds up.
Will report back.
Dazzalcr
338
324
Lancashire
Will report back.
I have a 200 cell sports cat on mine, it has passed its last 2 mots with it, but they are a pain, need too be nice an hot before going in. Mine needed a couple attempts to find the sweet spot but my mot bloke is sound and got it through, most can't be bothered to do it he said. Good luck
Reactions: Rich.T
bruceR
2,572
662
Monifieth, Dundee
Spent a couple of hours cleaning the engine bay and modifying my engine cover - ever since fitting the strut brace the cover never fitted
So measured and marked before slicing a section off
Sanded & smoothed the edges, have it a good clean then painted the I with red enamel paint (3 coats)
Fits and looks just right
Rich.T
1,609
932
Looks good but does it rattle now?
My pd had one of those rubber bungs missing and it did my head in on idle.
Thai-wronghorse
Self proclaimed Cupra R addict & butcher!
Dec 3, 2015
2,250
1,107
Kent
I did the same on my old FR TDI.
Sent from my SM-G986B using Tapatalk
Reactions: bruceR
bruceR
2,572
662
Monifieth, Dundee
What kit did you use on the headlamps?
Ive got a slightly frosty one.
So cleaned with Bilt Hamber Surfex HD, polished with CarPro Ceriglass + pad on Das6 polisher x 3 times, cleaned again then 3 layers of Meguiars Ultimate Paste Wax and buffed off with MF cloth.
Reactions: Rich.T
Nam-uk
1,256
408
lancashire.
problem with the cover the dam sound damping foam disintegrates due to age
iammooks
1,814
1,219
Bane of my life that engine cover. The insulation disintegrated, so stuck on some really thick stuff, only for that stuff to detach not from the cover, but from the adhesive, so now I have loose foam and the adhesive is stuck fast to the cover.
Have been meaning to pick up some silver covered stuff from eBay and see if that works, but every time I measure the cover to get the right size, I end up doubting my measurements and don’t buy any.
Rich.T
1,609
932
Hard to say. Didnt get out of a 30 zone driving home.
Wont know till Monday. Then its all bypass and roundabouts 😁
Nam-uk
1,256
408
lancashire.
Yep, I ripped mine off ages ago.
We use insulation foam at work (high temp stuff) so gonna try a bit of that and see if it’s ok
when contracting at vitafoam i wanted the same fire poof foam but none was there at time, wanted a rated temp foam as i did not want to chance it
Thai-wronghorse
Dec 3, 2015
2,250
1,107
Kent
That foam does absolutely sod all to reduce the clackety ole racket the PD engines make so I personally wouldn't waste my time and money trying to replace it.
Silent coating the bonnet would be more effective if you're aiming to reduce engine noise.
Reactions: iammooks
