Nik_130
Fitted an EGR delete pipe and then took it off as wasn't impressed with it !
The crow
106
new intake, filter, manifold polish
alternator light pulley neuspeed and steering ecs tuning
Garnaby
52
Blackpool
Investigated passenger foot well leak! Removed wipers/ scuttle panel and pollone filter / housing removed all the muck and leaves! re sealed the housing and fitted new filter!
bree9482
141
Glasgow
What did you seal the pollen filter housing with ??
Looks good !!
MOT passed, need new front discs(advisory), any recommendations ??
Took delivery of my Turbosmart boost gauge and nomad pillar pod ;)) can't wait till it's fitted !!
walsh107
23
Stoke
Fitted New high level brake light, 2 new indicator bulbs, new door seals on front, new rocker cover gasket, new coil over on the back after the current one cracked, replaced a caliper, replaced passanger front brake flexi, bled brakes, new disks & pads on front, New passanger side Hub on front wheel, wheel bearing on passanger side front, repaired broken wiring to drivers front ABS sensor, new hand brake cable and replaced the battery in my key fob after it stopped locking/unlocking the doors.
The joys of tidying up after previous owners that dont have a clue how to look after their car!! Only took 4 days to get it all sorted. Loving my LCR!! next thing is to get 2 chips on my wind screen repaired, 4 new tyres, Air con service, fit boost gauge (Great manual by the way whoever wrote it - will defo be using it!!) and get the alloys refurbed as 3 are gun metal grey and one is black, plus one is starting to corrode abit so need it sorting before it gets too much!!
Dougster
158
Clydebank, Glasgow
Dogbone with RED Powerflex bush finally done and a new swing arm and some seals replaced.
It's handling like a DREAM on the Bilstiens now!!
walsh107
23
Stoke
Re wired my speakers behind the stereo after previous owner decided to chop some wires to fit an after market stereo (obvs never heard of wiring harness). Managed to get a loom from a breaker and just finished. Gutted to see that 2 of my door speakers have blown so had to fit some speakers to the parcel shelf till i can replace the ones in the door.
Sent from my GT-I9300 using Tapatalk
rob swallow
113
alfreton
Swapped dump valve and relocated it and done n249 bypass. Wow. My standard dump valve must have been shafted coz performance wise its not in same post code now. Boosting well can hear turbo spooling up now where as before i couldn't and it now goes like it should
DuamoLCR
198
Brackley
Fitted this again as wasn't happy with how it sat
And found metal in the header tank :-(
Sent from my iPad using Tapatalk HD
joshy514
Fleet Air Arm by ability.
Mar 2, 2012
1,836
Gloucester
www.seatcupra.net
2x arb bushes, 2x top mounts and bearings and 1x track rod end and 1x and sensor on the silver leon. No more knocking amen! Tomorrow will be a clean and polish, and an interior Hoover and steam clean. I think I'm going to wrap the bonnet and change the door lock module and get it prepped for sale :).
Sent from my iPhone
walsh107
23
Stoke
Just give the old girl a clean before the footy :) nice relaxing sunday aftnoon now me thinks
csd_19
2,279
28
Angus / Edinburgh
Moved it back onto the drive after being abandoned in the street for the last few weeks, and began the strip down :)
Had a lazy day this morning so didn't get a whole lot done, just removed the seats and the W8 light, and tidied the garage up a wee bit.
stupot_1982
270
Modified the grills and fitted my DRL fogs, yes I will be using them as DRL's. Modified the switch so they works as DRL's are supposed to. Prob not to everyones taste but IMO they look better;
Also removed the front splitter, as my works multi storey does not allow it!:censored:
