csd_19
2,279
28
Angus / Edinburgh
Went to put the rest of the interior back in after having the carpets etc out for a bit to find and fix some water leaks, and noticed the underlay in the front footwells was a bit damp at the leading edge :(
So took that back out and stripped the wipers etc off to check for any other leak paths - found a rather obvious leak where the wiring passes through the bulkhead under the wipers so dried that off and covered it in silicon. Looks like one of the water guides had a clip broken at some point as the yellow foam stuff under there was hanging down instead of being held up secure. Couldn't see anything amiss around the pollen filter area though so unsure about that side at the moment - hoping the rubber skirt bit was slightly out of position around the filter although the filter was dry.
Also took the time to clean the muck at the bottom of the screen where the scuttle clips in and covers it, loads of gunk in there! :rolleyes:
8bit
3,401
Aberdeen
Today I washed the car, then clayed 2/3rds of it. Couldn't finish due to getting very low on clay lube and daylight, so the rest of the claying and some wax is next weekends job.
Yesterday I attacked the car with Tardis so now it has no tar spots any more. Also replaced the R badges.
Old:
New:
BEEFYGTI
625
Port talbot, south wales
Old:
New:
Did the badges come with an adhesive back ?
Sent from my GT-I9300 using Tapatalk 2
W11TTX
950
Cheshire
Just booked it in for a service cambelt and waterpump! Found out that the cambelt is over due by a year so not goin to drive it till it goes in on fri. Goin to use the misses's Ibiza if she will let me
jaf2212
202
Chesham, Bucks
After getting the wheels aligned today decided to get the car poly bushed at AMD essex just gotta book it in. Spent the weekend fitting some cheap wishbones and bushes which have failed within 200 miles (next time I'll do it right 1st time)
