rob280
135
53
Had a dent removed by autodentz Plymouth. Well happy with the result.
Sent from my SM-A405FN using Tapatalk
billman
120
19
The RacingLine dogbone mount states it’s not suitable for use for aluminium subframes - I’m assuming because of how harsh it is?
I’ve not managed to test the car properly yet - been on a short drive and car feels a bit tighter round bends at speed. Nothing else to report just yet.
I took these photos during the install, not sure if it helps:
Sent from my iPhone using Tapatalk Pro
Thanks for the photos. You placed it over the carpet, you didn't cut it? I didn't know that about the racingline mount. As far as the plastic trimming I guess you could have done it a bit better as you said! :bleh: :coolthumb I don't know how easy it would be to measure it and cut a hole with a hole cutter or a step drill for the tube and then cut the plastic in two horizontal lines and place it again. I don't know if you can understand what I am saying. I don't know if its possible to do it and of course everything is always easier behind a keyboard. If I buy one I will try it though. The shipping cost is killing me and is holding me back. 85£ for shipping is way too much for me.
Reactions: paddy6789
paddy6789
1,627
1,082
Preston, Lancs
Well I’m ordering new bits of plastic trim anyway, so I can use the ones I’ve got as a template to tidy it up. I used a dremel to essentially cut and sand the plastic into shape. Then got a bit tired of the back and forth so gambled and took too much off :(
Once I drilled the holes and put the nuts in the holes, I placed the carpet back over everything and then used a screw driver to pierce a hole for the screw. I then used a knife to cut a tiny hole to allow the screw to pass through to the nut. (Hopefully that makes sense)
Reactions: billman
billman
120
19
Yeah I understood how you marked the carpet for the hole. Regarding the plastic trim I don't know if a Dewalt laser would do the trick for marking the hole of where the tube goes through it. Masking tape on the carpet outside of the area that the plastic clips on with strut also on obviously and then marking with the laser. Then strut off plastic on and you find the center of the hole for the tube on the plastic trim. Drilling, cutting of the plastic etc.That's how I would do it.
who.am.i
Leon FR
Jan 23, 2016
392
30
EU
Finally fitted new summer tyres. Huge diference
Poslano z mojega SM-G390F z uporabo Tapatalk
Rooster
1,188
327
Yorkshire
Took the opportunity of the lockdown to replace the timing belt and serpentine belt kits, not the worst i have ever done but not the easiest either. Timing belt was coming up six years old but only done 37k, it was slack and was well polished and only showed minor cracking to the tooth roots and the backing surface, so didn't look like it would have given up any time soon, but you can't see the internal structure of the belt so i played it safe. Locking tools are required and make the job a lot easier and safer. Good practice though as i will do the Golf next year.
Reactions: Hag and Walone
H3I53
denmark
Gave it a proper wash, vacuumed the inside, gave the leather parts some leather soap.
Changed back to summer wheels
Would have removed the number plate frames, but the plate itself is screwed to the frame, which then again is screwed to the car.
So holes dont match if i remove the frame :censored:
Reactions: Hag
KXL
KXL
Dec 15, 2016
1,579
195
London, UK
Went to check the car, been sat there for weeks, went to push it a bit to avoid flatspotting tyres....found a large windscreen crack first (probably large ish branch fell on it), called to find out who's my insurer's approved glass repairer. Found out that I'm not an indicated key worker, so they won't be called out to replace the glass with no indication when they can eventually, so car will be sat there another month or so, forgot to push the car!
Reactions: Kirky
Rockbox
168
56
Reset service and inspection message as I cannot get it serviced at the moment even though I'm a key worker.
Alorjosh
159
70
East Anglia
Seen something a while ago. Behind the front plate, eazimods / others do a black wrap pre cut for this.
Anyone got a link
Fortis
40
Anyone got a link
Don’t think they’re a very good fit tbh, easier to buy some and cut your own shape
Hag
399
193
Quick wash.
It'll be up for sale end of this month, time for a Cupra :) pm if anyone's looking for a nice FR
Sent from my CLT-L09 using Tapatalk
Is that the Maxton Rear Diffuser/ Valance
