Eggy
129
Estonia
Should try this too...I have quite dark tint on the rear end and it is quite hard to see :D Actually i am searching for some extra lights to use, it would be nice to have some LED strip lights instead of the rear lower bumper red reflector strips.
Lentäjä
503
Helsinki, Finland
I called recovery truck to take it to the dealer. [:@]
When cruising at 100kmh, engine light flashed, EPC light popped on, engine start to run on 2 or 3 cylinders...
So i pulled over, stop the motor, did a quick scan on fault memory...
P0136 O2 Sensor Circuit Bank1 Sensor 2
P2237 O2 Sensor Positive Current Control Circuit/Open Bank1 Sensor 1
P0301 Cylinder 1 Missfire detected
P0304 Cylinder 4 Missfire detected
P0300 Random/Multiple Cylinder Missfire detected
Tried to start the car...nope...its spinning but does not fire up.:cry::confused::help:
CupraNJ
110
40
Bristol
Fitted four of these:
Not today, but two weeks ago. It's been damp and wet, but impressed with grip levels so far. Admittedly I'm comparing them to 2 year old Potenza's, which although had a bit of tread left were hopeless. Better curbing protection too.
Fixed now.
CupraNJ
110
40
Bristol
ZNNLvo
For some reason the image file linky thing didn't work. Dont know why, any clues? The image showed on of my shiny new PS4S tyres.
robby71
653
91
Yorkshire, UK
Fitted mist washer jets (Thanks Dan) today
Also finished fitting piano black climate front panel to match the piano black air and info surround i fitted last week
Fitted MK7 Golf GTi genuine pedals a couple of weeks ago (bought cheap chinese ones which were crap so threw them away) and today fitted a matching Golf GTi foorest :)
Bought a set of Cupra 18" alloys with Goodyear Eagle F1s which need a refurb to be perfect, not sure if i should fit them as is for winter?
g_berserk
Smartass in training
Oct 15, 2014
164
24
Monterrey, Mexico
Finally bought a new set of wiper blades in a VW dealer since they were three times more expensive at SEAT for some reason :blink:
Had to settle with 24/16 tho since VW doesn't have any car with 26" blades, but it's ok.
Also took the car for a quick wash for the first time in almost a month
niallain
273
54
Cardiff
How much did the pedals and footrest cost? Got a link to where you bought them from?
p.eco
227
17
Ireland
I have Chinese pedal set but cannot complain, very good made and a cannot see the difference in OEMS. Have them nearly 3 years now, no issues...
Sent from my Nexus 6P using Tapatalk
R4CK5
609
85
Essentially here is the steps to take depending on which year of car you have:
- Carbon Navi screen (for cars up to MY2015) Leon 5F,
Information Electrics,
Coding 70
Byte 17
Bit 0 false
Bit 1 true
Reboot the Radio (hold on/off button for 10 seconds)
- For cars from MY2016 or Navi plus, Leon 5F:
Coding 07
Byte 17
Bit 0 true
Bit 1 true
Radio reboot (hold on/off button for 10 seconds)
After doing this, my resolution decreased and all icons where big?[/QUOTE]Same with mine my17. I think I reactivated bit 1 and bit 2 was for the carbon screen. On the guide I used it said bit 3 or something and that didn't work so I activated the third bit in the list just as a stab in the dark and by some miracle it worked.
Sent from my SM-G950F using Tapatalk
Kinetic
118
35
Search for HEYNER Aeroflat Windscreen Wiper Blades 26"16" on Amazon, they were recommended somewhere on here.:)
zeffania
476
159
worked out why my passenger door vibrates from certain bass frequencies. Pull the handle and it stops. I shall be purchasing some clips and a foam rectangle and shall be gluing that to the door card for vibration free music :D
bega
205
My brother said always if you hear some noises in car,then music isnt that loud you should turn it up louder :)
I hate my self for kinda like this,everyhing needs to be perfect,I mean it cant but almost near perfect,but for him,he just dont give a crap about it :)
Sent from my G8441 using Tapatalk
zeffania
476
159
Ah, but that doesn't work when it is the certain frequency in the bass making it make that noise. Was Massive Attack this morning and thankfully I was stopped at lights so pushed and pulled the door. 95% it is fine, just that one frequency that the door doesn't like. Just a bit of foam to push the door away should sort it. Already asked the wife to grab me some clips from work as I am sure I will break one.
Just need to source some foam now. Edit - found some. Cisco switch packing, thanks very much :D
bega
205
Hope you will sort it out :) good luck and enjoy the music
