What LED did you use? How's the difference in the dark compared to original bulb?Fitted an LED for the reverse light today
Fitted four of these:
Not today, but two weeks ago. It's been damp and wet, but impressed with grip levels so far. Admittedly I'm comparing them to 2 year old Potenza's, which although had a bit of tread left were hopeless. Better curbing protection too.
For some reason the image file linky thing didn't work. Dont know why, any clues? The image showed on of my shiny new PS4S tyres.
Need to link the image directly if you're putting in the IMG tags
Fitted MK7 Golf GTi genuine pedals a couple of weeks ago (bought cheap chinese ones which were crap so threw them away) and today fitted a matching Golf GTi foorest
I have Chinese pedal set but cannot complain, very good made and a cannot see the difference in OEMS. Have them nearly 3 years now, no issues...How much did the pedals and footrest cost? Got a link to where you bought them from?
Essentially here is the steps to take depending on which year of car you have:
- Carbon Navi screen (for cars up to MY2015) Leon 5F,
Information Electrics,
Coding 70
Byte 17
Bit 0 false
Bit 1 true
Reboot the Radio (hold on/off button for 10 seconds)
- For cars from MY2016 or Navi plus, Leon 5F:
Coding 07
Byte 17
Bit 0 true
Bit 1 true
Radio reboot (hold on/off button for 10 seconds)
Finally bought a new set of wiper blades in a VW dealer since they were three times more expensive at SEAT for some reason
Had to settle with 24/16 tho since VW doesn't have any car with 26" blades, but it's ok.
Also took the car for a quick wash for the first time in almost a month
My brother said always if you hear some noises in car,then music isnt that loud you should turn it up louderworked out why my passenger door vibrates from certain bass frequencies. Pull the handle and it stops. I shall be purchasing some clips and a foam rectangle and shall be gluing that to the door card for vibration free music
I hate my self for kinda like this,everyhing needs to be perfect,I mean it cant but almost near perfect,but for him,he just dont give a crap about it
Sent from my G8441 using Tapatalk
Hope you will sort it out good luck and enjoy the musicAh, but that doesn't work when it is the certain frequency in the bass making it make that noise. Was Massive Attack this morning and thankfully I was stopped at lights so pushed and pulled the door. 95% it is fine, just that one frequency that the door doesn't like. Just a bit of foam to push the door away should sort it. Already asked the wife to grab me some clips from work as I am sure I will break one.
Just need to source some foam now. Edit - found some. Cisco switch packing, thanks very much
