What did you and your MK2 do today?
ECB
Edward CB
Jun 26, 2013
333
15
Northampton
Fitted my wind deflectors, not 100% sold.
connery-tdi
144
Essex
New discs, pads and tires for the rear today. Plus found out I have a broken spring so might be time to look into lowering it.
STU3Y
1,271
Kent
Just enquired about having a terraclean done to the Cupra, the guy quoted me £156.00!
I didn't think it was that expensive?!
Should only be around 95 ish. It is dependent on vehicle and how much work is required to access the fuel system.
STU3Y
1,271
Kent
Sometimes on petrols they charge up to £30 for an emissions test before and after to show the difference it has made, would be worth checking this wherever you go. I had mine done but I'm a 2.0 TDI, And mechanic said mine was one of the easiest as it literally just involves pulling a hose off and putting one on.
Tfsi_Mike
2,387
Doncaster / Germany (Army)
Used the hangar at work to drop the oil and take the sump off to check the oil pick up pipe.
Probably due to changing the oil at least every 5k the pick up pipe was perfect, Ill probably fit the new one though seeing as its in the boot.
Taking the sump to Alex at AKS on Monday to have a boss welded on so I can fit an oil temp gauge.
when I bring the sump back Ill be putting a new filter on and sticking some Millers Nanodrive cfs in. :)
olitaylor07
Badger Badger
Jul 15, 2012
2,422
West Yorkshire
I've got HID's in reflectors have the the H7R which are pretty good to be fair. If you have the adjusters on the lowest setting they aren't dazzling at all.
ECB
Edward CB
Jun 26, 2013
333
15
Northampton
Gonna fit mine tomorrow, quick question though do the clips just push up into the recess with the hook on the opposite side to the deflector?
Get them done fella , easy as you like only took 20 minutes. Yeah the barb/hook face in and the smooth side face out. I used a screwdriver to push them in, couldn't get them to say otherwise.
Dragon1978
139
Nice one thanks mate. :thumbup:
Craiglar
238
If the tape is sticky also leave windows shut 24hours
Rob_Talisman
MKII CR FR 170 FL Stage 2
Sep 2, 2013
811
North East
not keen on suede, but like the steering wheel.
booked in for stage 2 on tues with milltek dpf removal downpipe.
awaiting custom rear exhaust from nige at BCS in the next couple of weeks.
