What did you and your MK2 do today?
robthebubble
LED & Headlight Master
Feb 22, 2011
1,442
Solihull, West Midlands
Bought a set of FL bixenon headlights in need of some TLC. They don't come with either ballasts but they do come with bulbs! Once repaired they will be going on eBay!
Also got my H1 bulbs to test out my retrofit lights...will connect them up to the car at the weekend to check and take some photos before sealing them up!
May 31, 2011
748
Essex
qtp open downpipe,on my cupra.
Now that looks like an interesting bit of kit and also needs a video to hear it.
I'm guessing that when on full throttle the valve opens and goes straight out of there instead of flowing down full exhaust and everyone around becoming insanely death lol
jake
I AV MOSTLY BEEN BEATING
Feb 2, 2003
2,666
rochdale
wont that mess up the tuning of the car?
i did this
tried this today, and kind of failed,
the strut has to fix into the ball but its on too much of an angle for this to work so i modified the way its works and went the oem solution
i still used the plates, 20x50mm, welded the nut on the back,
how ever i went through the hinge
heres the hole
IMAG0223 by cuprajake1, on Flickr
after that to allow the strut to come down you have to trim this piece
IMAG0225 by cuprajake1, on Flickr
remove it
IMAG0227 by cuprajake1, on Flickr
cut in half
IMAG0228 by cuprajake1, on Flickr
install upside down
IMAG0218 by cuprajake1, on Flickr
i also trimmed the rubber 1/2"
this is it fitted up, no more bonnet stay :D
IMAG0215 by cuprajake1, on Flickr
IMAG0232 by cuprajake1, on Flickr
IMAG0220 by cuprajake1, on Flickr
IMAG0221 by cuprajake1, on Flickr
the struts are off an audi a4 13" long, while they hold the bonnet they dont lift it, so i need something stronger which i can have made by a company :)
Oct 3, 2012
580
Cambridge
Fitted a dash cam, been meaning to do it for a while.
I installed an ignition switched 5v supply in the fuse box, ran the cable up behind the A pillar trim, out the top and mounted one of these at the top of the screen on the drivers side,
http://www.ebay.com/itm/Mobius-Acti...FPS-720P-60FPS-Pocket-Camcorder-/151071891306
I would've liked it behind the rear view mirror but the wipers don't clear the screen so it wouldn't be as effective.
Good review here
http://www.youtube.com/watch?v=7wmIyD1fM4M
That camera looks really good, wanting 1 for some track days
shnazzle
Glass-Half-Full Member
Sep 9, 2011
3,483
Northumberland
A bit premature but found some time today so I prepped the car for winter.
- Full deep wash and cleanse
- intense SRP session working out quite a few surface scratches and blemishes,
- 2 layers of FinishKare 1000P sealant/wax ontop of the SRP.
- windows dressed with TW Ice rain repellant
It was a bit mucky...can you tell where I hadn't washed yet?
Now gleaming again
AndrewJB
Aug 16, 2007
11,209
485
Maranello
took the LCR to Rockingham for some track time.. it handled alot better than i expected was really impressed
robthebubble
Feb 22, 2011
1,442
Did a bit of plastic welding...rather pleased with the result and probably stronger than the original plastic now that its reinforced with wire mesh! These original FL bixenons will be on ebay before I know it!
J400uk
1,978
London, UK
Will do!, just need some repair tabs for one of the top connectors and one for the bottom and then they are ready to go...say next weekend!
Where do you get the repair tabs from and how much do they cost if you don't mind me asking?
The top connector of mine is damaged and it doesn't sit quite right anymore
robthebubble
Feb 22, 2011
1,442
Rob how do you go about plastic welding?
Sent from my HTC One X+ using Tapatalk 2
You use a flat tipped soldering iron, some fine metal mesh, and some matching plastic to act as the weld. You basically put small sections of the mesh spanning the crack, heat it up so it melts into the plastic and then top up with the new matching plastic. You need a steady hand too otherwise your make a right mess of it!
