WeeG Stage 3 APR Leon Cupra R mk2 TFSI (Banana) 436.5bhp 438.2lbs/ft torque
WeeG
3,407
Largs , Ayrshire
New intake fitted :)
WeeG
3,407
Largs , Ayrshire
Drove the new intake for 30 miles.
Here are my findings:-
Finish is first class
Set up is slightly quieter than my old one
Pick up is more aggressive
Top end power seems to be better
On block 32/33 on idle cars MAF readings are bang on 0% previously fluctuating 2 or 3 % on old intake
Air flow is up on WOT by 20 g/s
Very happy with the car as it stands :)
wild willy
2,323
Wales
Very impressive. I did alot of work on the 1.8T k04 large bore intakes and so can appreciate the flow gained here. What did you upgrade from... stock or an aftermarket setup.
When i upgrade to a MK2 in a few years time i'll design a monster intake for it....these 2.0T's are superb.
WeeG
3,407
Largs , Ayrshire
Had the VF intake willy with GROUP A KnN cone with trumpet, in fareness the MAF readings aren't 100% the piping was 2 1/2" and now 3". Has the heat shield etc :)
Mar 13, 2010
822
Like the look of that and flow gains are not to be sniffed at, if i buy a mk2 cupra id do the same as you, nice motor.
wild willy
2,323
Wales
I can't believe the VF was only 2.5 inch. 3 inch is ok but will still affect flow high revs. If your really hardcore put some 4 inch silicon (or 3.5) on and try an experiment. You will gain even more.
