Waste gate flutter
bowliog
120
Birmingham area
Should the mk3 tdi sport ibiza make noise thet sound like waste gate flutter on the rally cars. This as my friend has just purchased one and although it sounds very good one asks one self if there is somthing wrong.
mojogoes
You do get churping on the waistgates but this sometimes means it needs cutting back on the exhaust side, but this being a vnt sounds like it could be the bearings have you lost any oil check in the intercooler.
Fen
Gotta check my tracking..
Oct 21, 2002
1,683
Wellington, NZ
How exactly can you get chirruping on the wastegate? The wastegate opens on boost to control the boost level and stop the turbo blowing itself and the rest of the engine to bits. When you lift off, boost drops and the wastegate slams shut - if it does anything else it's fecked. Any noise you get from the wastegate would be on-boost and would be a whitstle or similar noise of air passing through it. No chirrups, squeaks, pops, bangs or whooshes.
The dump/divertor valve opens when the throttle is closed to give the trapped boost somewhere to go, but they whoosh if you can hear them at all.
If the car makes compressor stall noises then maybe the DV is stuck closed?
basstard
Dropping Cogs is Useless
Aug 24, 2002
2,746
Roma, Italia
I don't think that diesel engines have DVs because they have no throttle valve to preserve. That's the reason why pop-offs are useless on diesel engines.
Scotty_b
Leon Cupra 300R
Jun 3, 2004
6,026
66
Hertfordshire
what a pain i love the sound of waste gate chatter (had an old rst fiesta) mite have to get a sound recording so i can listen to it in the LCR!
enigma
109
its not the throttle plate they protect its the turbine blades on the compressor side of the turbo as the throttle plate slaming shut means the boost has no where to go but back , thus slowing the turbo down or casuing damage.
and no diesels have no throttle plate , they are controlled by the amount of fuel not the amount of air and typically run lean.
basstard
Aug 24, 2002
2,746
Roma, Italia
2004, ok. There's a sort of a back-from-the-dead trend on these boards lately uh? Take it easy guys cos this forum only started in 2001!! :cartman:
Correct, it's more for the compressor safety.
Muttley
Catch that diesel!
Mar 17, 2006
4,987
31
North Kent
Any diesel other than a TDI 90 doesn't have a wastegate, all the more powerful engines have VNT turbochargers, and the VNT replaces the wastegate as a boost control mechanism.
I strongly doubt your Mk.3 TDI Sport is a TDI 90 engine, but check the engine code to make sure.
techie
Skoda Techie
Mar 22, 2003
5,438
Worcs
Even the 90bhp 1.9 TDi post 2001ish had VNT.
