Viper Induction kit
bigjode
504
is that a 4% increase in airflow or a 4% drop in air intake temperatures? the charge air is heated up when compressed by the turbo and then passed through two intercoolers so in my humble opinion i can't see why having cold air go through only to be then heated up then cooled down again is so important. does the MAF measure just airflow or the temperature of the incoming air?
Airflow.
The effectiveness of the mod'd airbox can be see by logging MAF readings of g/s of air coming in.
Mine increased a huge deal with a mod'd airbox, whilst only marginally with a BMC.
It really does work, eveyone that has done and logged the results has amazing results.
karlosR
TORQUEY, NOISEY V6
Mar 10, 2006
1,469
BEDFORD
so i'm sort of right then, an increase in airflow is a good thing but it isn't vital that is cold, denser air.
J@mes
e46psi.com ;-)
Jun 14, 2004
2,842
4% increase in volume AND density!
the MAF measures density (IMO) so the more cold air it sucks in...
as for whether cold air going into the turbo is a good thing... of course it is!
its better for the turbo and if it didnt matter why would we have intercoolers to cool the air?! ;)
J@mes
e46psi.com ;-)
Jun 14, 2004
2,842
Airflow.
yep! :yes:
its just we dont get the sound of the BMC/DV as much! :( :rolleyes:
karlosR
TORQUEY, NOISEY V6
Mar 10, 2006
1,469
BEDFORD
that is sort of what i'm getting at in an indirect way. i understand that heatsoak and high intake temps can be bad for power and cause pinking/detonation. on a n/a car its better for cold air to be directed through the filter as there isn't any intercooler to bring the temps down. but for a turbo car when you're givng it some beans the turbo gets really hot (mine glows cherry red!) so no amount of cold air would help there would it? to me (again, my humble opinion) the only effective way to reduce charge temps is either a more efficient intercooler, water injection or those spray kits for the intercoolers like evo's have.
Big_daddy
Going going gone.....
Oct 20, 2006
3,930
Brummy
here is how i fitted my viper kit. Im not photographer nor is my phone.
[/IMG]
That how i routed the pipe into so it take cold air from the grill exit
J@mes
e46psi.com ;-)
Jun 14, 2004
2,842
good man, looks good... try and get a cupra touring LCR air scoop tho! ;) about £40 from darren at northen south! (DO A SEARCH!)
also out of interest u got any more pics of ur engine bay, be nice to see a pic with everything insight! (the viper! ;))
J@mes
e46psi.com ;-)
Jun 14, 2004
2,842
i understand your thinking, but like urself im not mechanically minded enough to know tbh!
as we both know on NA engines its different, as the cold air goes through the air filter straight through the TB/inlet manifold and into the engine... rather than to a hot turbo like you said!
but all i know is as much cold air as poss is obviously the best idea! :)
over and out lol
bigjode
504
The point about cold air is that because its denser, you get more of it in a smaller amount of space.
I see your point regarding temperature, its all baking in there anyway, but with colder air you're basically getting more air for your money into the system if that makes sense.
Big_daddy
Oct 20, 2006
3,930
Brummy
Here are some xtra picture fo engine bay, mines phone ins not all that (drop it on various occasions)
[/IMG]
[/IMG]
Big_daddy
Oct 20, 2006
3,930
Brummy
Yeh its decent size, the smaller the size, the better the suction from cold feed, from the out side
J@mes
e46psi.com ;-)
Jun 14, 2004
2,842
big lad... looks good... as for the k&n typoon... YOU CAN get one as you have the cupra! :yes:
i thought u said u had a LCR! :doh:
Big_daddy
Oct 20, 2006
3,930
Brummy
oops slip of the key, typoon nice but the viper are better in taking more air than a typhoon kit :rolleyes:
J@mes
e46psi.com ;-)
Jun 14, 2004
2,842
are they tho?! :shrug: ;)
the typhoon will be like the cabrino (sp!) which sits low down by the fog light to suck in lots of cold air! (its an open cone filter too!)
makes ur DV sound good too! :yes:
Big_daddy
Oct 20, 2006
3,930
Brummy
hey guys
im thinking of rerouting the cold air feed to the bottom of the grill. Will this effect it in any way as the cold air feed is abit longer than before? the car air feed will point right out side, but not sure if the lenght of the pipe will effect it.
any opinions?
bigjode
504
hey guys
any opinions?
Best thing you can do IMHO.
When I removed my foglight and routed my air intake tube down there, I got 180g/s through my MAF. when it was pointed down, i was only gettin 170+
Big_daddy
Oct 20, 2006
3,930
Brummy
so wats the best suggestion? at the moment its squeezed in top section where the orignal one is, think if i face toward the front bottom grill, will i see any improvements.
is it easy to take the front grill of only? where the seat badge is.?
bigjode
504
No not that grille, I don't think that comes off. Route it down to the foglight region and aim it out of a grille facing forward. I had to actually take out a foglight on mine as there were no empty grilles to route it out of. Your bumper is different to mine though
Big_daddy
Oct 20, 2006
3,930
Brummy
will that make noticable differnt from the current point i have and by facing it toward the bottom toward grill exit
