Viper Induction kit
Big_daddy
Going going gone.....
Oct 20, 2006
3,930
Brummy
Just reivecved my induction kit for seat lean Cupra. I fitted every thing ( luks nice).
The problem is i need to fit the cold air feed pipe. i want it to be at front grill , so it take desnse air into the system
Any suggestions where i could feed it from?
J@mes
e46psi.com ;-)
Jun 14, 2004
2,842
this is my modified airbox, you could do the same cold air feed. mine is 102mm but i suspect u would need an 80mm feed to fit onto ur piper x viper!
hope this helps?! :)
J@mes
e46psi.com ;-)
Jun 14, 2004
2,842
No dis-respect..But you bought the wrong induction system.
wats the "right" induction kit?! :blink: :shrug:
i know this wasnt aimed at me m8, but different ppl want differnt things from an air filter...
i wanted best performance and vfm, hence i did a modified airbox!
some ppl want noise so go for an open induction kit
and some ppl want noise and performance so go for dynatwist, ram air etc etc!
there is no "right" answer! ;)
Big_daddy
Oct 20, 2006
3,930
Brummy
Hi james
do you have to remove the light cap cover.
Do i need to drill a hole into from grill. ?
CupraJay
20v T - Its where its at!
Jan 17, 2006
333
South Wales
You payed more money, for an imitation.
Viper design was taken from the BMC CDA. A true, performance filter. Found on alot of top spec race cars.
Its around £100 cheaper, and does the job properly. More than anything, the viper just looks good. You'l get nice gains from it. But it wouldnt have been my choice.
panholio
333
Leeds
Think BMC kits and Dynatwist are the flavour on here mate.
As far as I know the Viper is a very good system indeed, mate of mine has had excellent results with one on his 306 GTi-6.
Looks cool as well...... don't you get some of the tubing james has used with the kit? Looks like a good solution but a bit of a bodged fit round the battery
Are there really that good a gains to be had with an induction kit on a turbo'd car? Other than noise obviously.
Big_daddy
Oct 20, 2006
3,930
Brummy
True True, Mines performance all the way!
:lol:
CupraJay
Jan 17, 2006
333
South Wales
This is true..but since he went for a carbon fibre filter. I would have gone for the CDA.
Big_daddy
Oct 20, 2006
3,930
Brummy
The only reason why i choose viper, is because i had it on my golf tdi. It improves the trottle response alot and better acceleration.[B)]
J@mes
e46psi.com ;-)
Jun 14, 2004
2,842
Hi james
do a search m8, i did a big thread with logs to prove before and after increase! ;)
no u dont need to remove the light cap cover
no holes to drill in grill or at all!
i have a battery relocation bracket from "Feel" on here which enable a 102mm feed to fit around the battery otherwise u will have to go for a 80mm size pipe (which as said i believe came with ur viper?!) just use that! :)
J@mes
e46psi.com ;-)
Jun 14, 2004
2,842
i dont want to argu here, but how do u know the viper was based on the BMC?! :shrug:
the BMC is very good, it was either that or the moddified airbox for me! ;)
also i thought the viper was £250 and the BMC is £200 for us LCR boys! so only £50 difference! [B)]
J@mes
e46psi.com ;-)
Jun 14, 2004
2,842
...don't you get some of the tubing james has used with the kit? Looks like a good solution but a bit of a bodged fit round the battery
bodged fit?! :cry: (i have used battery relocation brackets from "Feel" on here! ;))
IMHO opinion it looks great! (pics dont do it justice!) everyone who sees it is impressed! :yes:
as for gains to be had... i did before and after logs on the same road with the same ambient temp and got a 4% gain from memmory!
so for vfm is good!
i suck in over 200g/s all day long, best peak of 210g/s :D
J@mes
e46psi.com ;-)
Jun 14, 2004
2,842
SO ANYWAY big lad... lol...
did urs come with the 80mm air feed?! :shrug:
if so put it on like mine! ;)
