Phillips1795
VCDS - How To Guides - MK3 Leon 5F
simonali
834
36
Wiltshire
What I'd like is to turn off that irritating thing where you're in 4th gear (DSG in manual mode) and the car is telling you to change to 5th every time you brush the throttle, even though the engine is only doing about 1800 rpm...
simmo1
60
Estonia
I like the option in "eco" profile where letting go the throttle pedal car shifts to N (with DSG) and just cruises. Is it possible to set the same function for "normal" profile?
I don't want to stay in "eco" profile.
TobyAnscombe
19
New to all this - Only got my car a couple of weeks back...
I have a proper Ross-Tech cable from when I had an A5 so fired up the software and had a look.. Got a couple of faults:
Address 01: Engine (J623-CUPA) Labels: 04L-907-309-V1.clb
Part No SW: 04L 906 021 EL HW: 04L 907 309 D
Component: R4 2,0L EDC H22 6556
Revision: 83H22---
Coding: 01190012032501080000
Shop #: WSC 00049 770 00127
ASAM Dataset: EV_ECM20TDI01104L906021EL 002007
ROD: EV_ECM20TDI01104L906021EL_SE37.rod
VCID: 73EF24CBDAFCA0B9629-8026
2 Faults Found:
18115 - Oxygen (Lambda) Sensor B1 S1
P0132 00 [032] - Signal too High
Intermittent - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
18826 - Coolant Pump for Intercooler
P190D 00 [032] - Mechanical Malfunction
Freeze Frame:
Readiness: 0 0 0 0 0
Address 03: ABS Brakes (J104) Labels: 5Q0-907-379.clb
Part No SW: 5Q0 907 379 R HW: 5Q0 907 379 F
Component: EMB8 EHCB H31 0356
Revision: 00000000 Serial number: 60184000001105
Coding: 20EE8A9234280971007B060341C62904512C9000608294F400610060C003
Shop #: WSC 00049 770 00102
ASAM Dataset: EV_Brake1UDSContiMK100ESP 033001
ROD: EV_Brake1UDSContiMK100ESP.rod
VCID: 4B9F9C2BE28C9879CA9-801E
1 Fault Found:
16401 - Tire Pressure Warning
C102D 00 [008] - -
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 1
Reset counter: 45
Mileage: 24354 km
Date: 2014.12.14
Time: 14:19:44
Address 09: Cent. Elect. (J519) Labels: 5Q0-937-08X-MV1.clb
Part No SW: 5Q0 937 084 AC HW: 5Q0 937 084 AC
Component: BCM MQBAB M H16 0124
Serial number: 00011402101283
Coding: 0B000842C24100DB0BA44000B10403281000000000000000000000000000
ASAM Dataset: EV_BCMCONTI 012001
ROD: EV_BCMBOSCH_SE37.rod
VCID: 79F316E3F890DAE9285-802C
Subsystem 1 - Part No SW: 5F2 955 119 HW: 5F1 955 119
Component: WWS370 131209 041 0574
Serial number: 131212203322
Coding: 0BC5FD
Subsystem 2 - Part No SW: 5Q0 951 171 HW: 5Q0 951 171
Component: Sensor, DWA 005 0315
Serial number: 000000000ZY133231CSV
Subsystem 3 - Part No SW: 5Q0 951 605 HW: 5Q0 951 605
Component: Sirene, DWA 004 0311
Serial number: 00000000000058683424
Subsystem 4 - Part No SW: 8U0 955 559 HW: 8U0 955 559
Component: G355_FeuchteS H07 0002
Serial number: 20620944
2 Faults Found:
11274 - Bulb for Center Brake Light
B12C6 15 [008] - Open or Short to Plus
Freeze Frame:
Fault Priority: 1
Fault Frequency: 3
Reset counter: 43
Mileage: 24326 km
Date: 2014.11.27
Time: 08:02:17
197904 - Central Locking
B140A 4B [008] - Over temperature
Freeze Frame:
Fault Priority: 6
Fault Frequency: 3
Reset counter: 43
Mileage: 24326 km
Date: 2014.12.01
Time: 09:24:37
Address 5F: Information Electr. (J794) Labels: None
Part No SW: 5F0 035 869 A HW: 5F0 035 869 A
Component: MU-E--ER 635 5800
Serial number: 06121300010334
Coding: 04730000FF00000011110001000000002F0007860000010000
ASAM Dataset: EV_MUEnt4CLGE 001025
ROD: EV_MUEnt4CLGE_SE37.rod
VCID: 2B5FFCAB424CB879EA9-807E
3 Faults Found:
1564 - Microphone 1
B129B 13 [008] - Open Circuit
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
6930 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 4
Reset counter: 52
Mileage: 21591 km
Date: 2014.10.09
Time: 17:16:15
7176 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 43
Mileage: 24342 km
Date: 2014.12.10
Time: 14:42:14
The Lambda sensor is obvious, as are the brake lights (must check!) but the coolant pump worries me slightly... any thoughts?
AJ
250
Anyone got the coding for adjusting the DRL's when the headlights are on?
Hi Zombie, are you wanting to adjust the DRL's so they are brighter when the headlight is on? If that is what you want to do then here is a tip, whatever value you set for the DRL brightness with dipped headlights I would recommend setting the same value for when indicators are on. If you didn't and the value for the indicators were lower say, then at night when the headlights are on and when you signal the DRLs will dim (you can see by default the values are the same) I made this mistake and found it annoying! lol :D
Here are the instructions which I made a note off when doing mine initially, I have reverted back to standard settings now though.
Hope this helps
DRL dim Adjustments option in VCDS is:
*Go into [09] Central Electronics
*Go to Secuity Access and enter 31347
*Go into Adaptation
*Then change the channels as follows:
To adjust DRL brightness when Dipped and Side lights are on -
default value = 35
LHS - "(6)-Leuchte2SL VLB-10-Dimmwert AB2"
RHS - "(6)-Leuchte3SL VRB-21-Dimmwert AB3"
To adjust DRL brightness for when Indicators are on -
default value = 35
LHS - "(14)-Leuchte2SL VLB-10-Dimmwert EF2"
RHS - "(14)-Leuchte3SL VRB-21-Dimmwert EF3"
Tommy95
66
26
Coventry
Hi All, New to the whole forum thing, but i am trying to make a few changes using vagcom but I'm having some problems, hopefully somebody could help me out :)
I have downloaded various copies of vagcom from freeware to the official lite version, and I am using a cheap elm ebay cable. The software tells me it finds the interface using COM3, but when i try to run a autoscan or access any modules it comes back unresponsive. Is there something I'm missing or have i just got the wrong tools. Any help would be appreciated, or if anybody near coventry with vagcom could help it would be appreciated. Thank you!
Suicida1 Zombie
446
Hope this helps
*Go into Adaptation
default value = 35
default value = 35
You my friend are a star!
altea-ego
176
Hi Zombie, are you wanting to adjust the DRL's so they are brighter when the headlight is on? ...
Why did you revert back to standard btw?
altea-ego
176
Activation of the fog lights (NSW) and Cornering
The onboard supply control unit, you have the option of the Seat Leon 5F fog lights (NSW) to activate additional as cornering. With active low beam, the respective front fog lamp is thus driven in accordance with steering angle and thus provides additional illumination when turning.
1. Select 09 – Cent. Elect.
2. Select 16 – Security Access
3. Enter Unlock Code 31347 active - Click DO IT! And yes if it brings up other boxes
4. Select 10 -Adaptations
5. From drop down select - (5) Leuchte12NL LB45-lichtfunktion B 12
6. Set Value to Abbiegelicht links active - Click DO IT! And yes if it brings up other boxes
7. Staying on same page select - (5) Leuchte13NL RB45-lichtfunktion B 13
8. Set Value to Abbiegelicht rechts active - Click DO IT! And yes if it brings up other boxes
Step 7 has an error in it, should say.
"7. Staying on same page select - (5) Leuchte13NL RB5-lichtfunktion B 13"
see the image for the correct entry.
Once step 7 is done, later checking the value on step 6 says ERROR channel not available.
AJ
250
Hi Altea-ego, I switched back as I wanted to keep it so that the daytime running LED lights would dim when the indicators came on during the day. But with my new settings it meant that when indicating at night the LED would also dim :)
Suicida1 Zombie
446
Also, can I just confirm that the 'value' is a percentage? I am pretty sure it is, just wanted to be certain.....
jaba101
196
South West
So I have been in contact with Ross Tech to find out why the differential lock adaption is now missing from 03-ABS, and after several emails it's looks as though it's not. It's now called No Display, I have tried it tonight logging in first with access code 20103 and I have set it to strong. Think they made a little mistake and forgot to name it correctly. Hope this helps someone in the future.✌
