I'm like my cat after he's losses a mouse keep going back to the same place.
I've found this post in Russian which seems pretty key as far as the SSD systems are concerned
https://www.drive2.com/l/464916398250918465/
In English
https://translate.google.co.uk/tran....drive2.com/l/464916398250918465/&prev=search
I stumbled over the SWDL command of the Green menu in Italian by Googling the text in the metafile update to see what people were talking about and then work backwards. SWDL command took us to our Russian friend...
The as yet unreleased SSD maps for June 2017 is here
https://www.briskoda.net/forums/topic/431125-direct-download-links-for-ece-20172018-maps/
Discover Care that I mentioned further up gives gives you the current version for SSD (MIB2High)... the Russian guy says he's done it on MIB1 and MIB2 these are the disc based / SSD card systems not SD which has the workaround... that's my reading. The update time of 50 minutes tallies with the SSD map times.
http://en.volkswagen.com/en/innovation-and-technology/discovercare.html
Pretty important to make sure the update SD card or USB is FAT32, no hidden files etc. The Discover Care software one suspects was released by VW to iron out MAC issues with hidden files.
Then you got this one here in Italian where Dillario has a
problem.... still researching it before I try it.
https://www.seat-leon.de/vboard/sho...nssystem-plus-Features-und-Erfahrungen/page55
Fools rush in etc. Feel free to test this before me
. I'm going to look at putting my MIB2High
Ateca Plus unit into the engineering menu via
OBDEleven then see how it goes. The unreleased June 2017 file has been used by German
Ateca board posters with Mapcare so we know that works. All the MIB2High updates are the same irrespective of which VAG car it's used against.
So yes, I think this is the SSD workaround for the map updates. Assuming why the guy is doing like this since Mapcare is not available. Something for MIB1 users here as well I think. I'm thinking that the units without Mapcare enabled just don't have the software for the important but you do it manually via the backend. Manually was another word in Italian where SWDL command was mentioned.
Edit. I notice in the translated Russian to English comments on the top link some serious bitching which doesn't appear to be restricted to boards in the west... difficult to tell whether its over it not tangibly working with a user error or whether the Mib2 and Mib1 are modded. Still researching it since I don't want to brick my unit. I've been told that it still won't work (and it will wreck your existing maps)... I don't think they had tried it mine you. Decided that I'm not prepared to risk my unit. The search goes on for the MIB2High solution, but the Briskoda and Discover care links are still good for anyone who has Mapcare and the MIB2High unit it's all the same update across the VAG group.
Edit. Yeah it's the retrofit Mib2's Pros that can be updated via the SWDL (& Mib1), still checking what happens if you do it with a non Mapcare, non retrofit unit. Someone said hell fire etc but I'm thinking the md5 file to protect the unit against flagged units that can and the lack of the engineering menu unless enabled is the front line, but still researching the subject.
Edit. DON'T DO IT. Resolved that one. Take my word on that.
