UPDATE: Well I found out what the
problem was.....when the box went pop!!
Turns out the end bearing on the gearbox main input shaft was f*cked & broke up - spitting its contents onto the undertray & causing 5th gear to grind horribly.
To keep costs down I've decided to pull the box myself & get it sent off for repair.
I used a haynes manual (for a golf) for guidence & main steps ae below (usual disclaimers apply - I am not a qualified mechanic & this is just a basic
guide):
- Remove engine cover
- Disconnect & remove battery
- Remove entire airbox assy
- Remove battery tray
- Loosen starter motor wiring from its clipping & disconnect from starter motor
- Unbolt top starter motor bolt
- Loosen wheel nuts & jack up car (support on axle stands)
- Remove Engine & passenger side undertrays / side shields
- Remove both front wheels
- Remove starter motor
- Disconnect any wiring / clutch hose (keep clutch hose vertically supported to avoid fluid spillage) from box
- Undo gearbox oil drain plug & drain oil from box
- <Back to the top> Disconnect selector cables from the box & undo the bracket from the top of the box, pull cables clear of box
- <Under car> Unbolt both driveshafts from the box (M10 spline bit required for this)
- Locate 3 bolts on lower wishbone which hold the upright to the wishbone & use a scribe to mark around the upright bracket relative to the wishbone (so everything goes back together in the same place!)
- Remove lower rear (dogbone) engine mount
- Undo the bolts & pull the upright away from the wishbone
- Pull the driveshafts away from the box & the upright away from the wishbone, tie the wishbone up out of the way
- Unbolt & remove diff output flanges (gives more space on box removal)
- Support weight of engine & weight of box seperately (I used a hoist on the engine & a trolley jack on te box)
- Unbolt & remove passenger side box / chassis rail mount
- Unbolt all gearbox / engine bolts
- Slide box off input shaft & somehow wiggle, jiggle, force & twist the box out from between the engine & subframe & onto the floor (this bit is tricky & you may need to drop the subframe a bit to give more clearance - I did!)
Obviously this is only a rough
guide & I may have mixed up a fewsteps / missed some out. I hope it can
help someone else in a similar sitation - or even just needing to do a clutch change)
I can't give a refit
guide as the box is still away being repaired!!!
