also another sign of a failing dmf is when you come down the gears and do not match the roadspeed (revs race up when you release the clutch) you will most likely get a squeek from the clutch pedal
Mine has started making this noise now. i thought it was my turbo at frist but looks like this, sould like i need my clutch Re-con and a new clutch, does your flywheel always need replacing with your clutch??
