Topping up oil
danny m
321
Hi all
How often do you have to top up your oil in your lcr? Do these car's use much oil? never had a turboed car before. when i do check it most of the time i have had to top it up.
Cheers :)
seatcupra2001
150
Andover,hampshire
Hi all
Cheers :)
i have this problem i contacted seat about it they said they either drink a lot or none at all but i asked jabba motor sport wen i was up there they said if you over fill the oil it jus burns it ;)
danny m
321
intresting mate, im going to keep my eye on it cant see it being nothing to servere with 16500 miles on the clock but who knows! If it carrys on i will take it back down the garage.
thanks for your reply.
GREY 225
Jim R
Oct 15, 2006
445
Depends how you drive it really, i wouldnt be concerned about any engine using oil during service intervals as long as its not excessive and smoke is present.
I probably use about 1 lt of mobil 1 every 10k.
danny m
321
thats about how much im useing i think roughly. i'll stop worrying then. :)
turbin
my LCR used oil for a while, or so I thought. Turned out to be a tiny leak in the PCV system. New parts and now its not using any oil whatsoever. Mobile 1 0w-40
danny m
321
turbin: I mite have to check this aswell. sorry to sound dumb where would i find this. totally new to these cars. :)
rsmith: ok cool wanting to do a 5k oil change just waitin on the wheather!!!! im useing quantum synta gold 5w-40 i take it this is ok?:)
stewbie55
No longer a Newbie
Aug 12, 2006
427
I've had two 1.8T's and both have hardly used any oil at all, can maybe squeeze in 0.5 litre between oil changes.
Quantum Synta Gold is good - what I use on mine and Bill uses on his racecar.
turbin
-just dig your head down in the enginebay with a torch and look for wetspots of oil on the block or on hoses. Those rubberhoses in the PCV system are fairly weak. Mine is a BAM angine and I was told they fixed the hoses on the BAM engine but no dice. Was a rotten hose.
