How often do you have to top up your oil in your lcr? Do these car's use much oil? never had a turboed car before. when i do check it most of the time i have had to top it up.
i have this problem i contacted seat about it they said they either drink a lot or none at all but i asked jabba motor sport wen i was up there they said if you over fill the oil it jus burns it
intresting mate, im going to keep my eye on it cant see it being nothing to servere with 16500 miles on the clock but who knows! If it carrys on i will take it back down the garage.
Depends how you drive it really, i wouldnt be concerned about any engine using oil during service intervals as long as its not excessive and smoke is present.
I probably use about 1 lt of mobil 1 every 10k.
my LCR used oil for a while, or so I thought. Turned out to be a tiny leak in the PCV system. New parts and now its not using any oil whatsoever. Mobile 1 0w-40
-just dig your head down in the enginebay with a torch and look for wetspots of oil on the block or on hoses. Those rubberhoses in the PCV system are fairly weak. Mine is a BAM angine and I was told they fixed the hoses on the BAM engine but no dice. Was a rotten hose.
