the mac music mobile
Apr 4, 2011
572
woodford green
Mac is removing the A Pillar easy and quick to do? with no damage to air bag system? once the pillars are off the holes should be simple enough for me to do and mounting them.
any instructions on removing the pillars?
Matt
hi Matt yep simple the " airbag " rectangle " at the top of the pillar ease that out & undo the screw behind T25 i think , but dont curse me if its T20 ! then pull it off , there are 2 spring clip fixings lower down that 'thump' back when you put it back
here is the offending screw
once off you see this
i put the tweeter about here & you can see a clip that got stuck in the door
hope that helps
MM
