Team Heko Wind Deflectors - Help!
Suicida1 Zombie
446
So I bought a set for my 5 door FR and they arrived yesterday.
I had a quick go (Would have been a rush job so I stopped once I ran into toruble) last night at fitting them.
I started with the rear drivers side that seemed quite loose but I thought that with the clips and adhesive they should be ok. But then I found the rears only have one clip each in our set and can't see where best to fit the one clip to give the best support (Let alone how to actually fit/insert it).
I found this video today, it makes the clip fitting/insertion make more sence but it shows the rears (Starting at around 1:52) having TWO clips where as my set only has the ONE.
Can anyone with experience with the Team Heko ones shed some light on this for me? Always had Climair in the past and have never had to use adhesive strips or clips.....
smurf123
318
swindon wiltshire
hi i put heko ones on my previous car and were excellent they came with 2 clips per window but i have seen just the clips for sale on ebay have a look there
look on ebay (ebay no 171245675717 ) 99 pence
Villers
Billy Villain
Apr 12, 2014
181
Cumbria
www.horizonwatches.com
Suicidal Zombie, once you get this sorted can you come back and let us know how they perform? I'm after a set of these so I'm curious how well they work and if they remove that horrible buffeting noise you sometimes get in cars when you only have one window open. This is mainly because I'll have a basset hound with its head out the window! ;)
Suicida1 Zombie
446
Your a star, two bought but might have a go tomorrow anyway.....
Sent from my GT-N7100 using Tapatalk
Suicida1 Zombie
446
Fitted them today, the front's fit great, (almost so well that I don't feel they even need the clips) but the rears could definitely could do with an extra clip each for peach of mind...
They DON'T stop that wet fart noise that you get when you open one window all the way and have the rest closed. But you CAN have all 4 down an inch or two with no wind noise at all but a nice flow of fresh air running through the car.
The main thing I will use mine for is to cool the car down a bit and clear the stuffy air out of the car and cool it down a little when its not massively hot outside but don't want to wase fuel using the A/C for a change....
robbyd6
28
wirral, merseyside
Suicida1 zombie did you get your deflectors off Ebay?? If so what was the sellers name?? Just ordered a set myself off ebay and if its the same guy could do with buying extra clips now so I don't have to leave them in the box for too long and can get them on the car.
Rob
Suicida1 Zombie
446
I did indeed!
The seller I bought the set from was 'automotive_jandj' and the seller I bought the clips from was called 'winddeflectors' (I used the item number that smurf123 was good enough to give)
Suicida1 Zombie
446
I'll see if there is enough light when I go out for my break ay work in 15 mins....
Suicida1 Zombie
446
Well the car is dirty, the lights a bit crap and its just started to rain but you still get the idea....
Reactions: R2m1
Suicida1 Zombie
446
Yeah, there are nice and slim and sit with a low profile, look better than the climair ones I used to have on my old ST IMO and yeah, they are the smoked tinted ones so the match the rears quite nicely......
Suicida1 Zombie
446
I am sure someone put up about sc wind deflectors the other week..... hang on....
smurf123
318
swindon wiltshire
cheers mate thank you for that had a look but not heko ones as i had heko on previous car and they were brilliant have to wait they will do them for sc sometime
