Stretched tires.. HELP! :(
Mythbuster
352
Made, The Netherlands
Hi guys! I see I missed a lot here, somehow I forgot about the forum a bit but I'll try reading back later...
First of all, my Ibiza is still going strong so that's pretty good...
Second, I need help.
I'm planning on getting my steelies banded/widened from 6j to 7j in a couple of weeks. Problem is, I don't want to buy new wider tires as they're quite expensive for me and I like the stretched look and I just had new front tires... My tire size is 185/60HR14 (and I'm running Blackstone CD2000 tires, which are about 85 bucks for 2, so very cheap tires).
So I've been looking around the web for a bit and been asking some people about stretching tires and everyone has been telling me different things. I work at a tireshop in the weekends and I think my boss doesn't have any experience with stretching tires over a wider rim...
(btw, 185 tires are 7.2 inch wide, as you guys don't meassure in mm like we do?!)
First I asked him if it's possible for me to go from 6j to a wider rim with the same tires and he told me "well you can go to 6.5 but not to 8 otherwise it's dangerous"... So I looked up some stuff and I was like, well 1.2cm is a bit of a waste of money, but a full inch wider would be good. So I asked him, and he said it would be dangerous, and I said I've seen loads of people with stretched tires on the web. He then said "then do it and we'll see"...
So about a week later I asked my dad if he could ask my boss(as he was going there anyway) how and where it would be best to store the Ibiza with no wheels while they're doing my steelies...
Apparantly, the previous owner of my Beeza(who was also at the shop apparantly) and my boss told my dad it was super dangerous and all that to stretch tires over an inch too wide... I was like what the hell? :wtf: Why are people running 225 tires on 10J then, that's a full 1.2 inches too wide. and that is apparantly not dangerous? So I texted that to my boss and I got nothing in reply as of yet.
Also, I've been hearing mixed opinions about whether or not you need to take drastic measures to get a tire to pop the bead on a wider rim, some say you do(using brake cleaner and fire...) and others say you can just do it with a regular tire machine that ever tire shop uses...
I assume the shop where I work apparantly has never stretched tires before, or even know about the millions of people that have them, and therefore assume it's dangerous?
Plus, something I just thought about, is it the J shape of my rims that make it more dangerous, as other rim shapes cannot loose the bead of the tire as easily and are therefore safer to stretch or something?
What my question with this thread is: What are your thoughts on stretching tires? Can I go an inch wider without buying new tires? And can I fit those tires on an inch wider rims at my regular tire shop(which is where I work :) ) without having to mock about with fire, bicycle innertubes or any of that odd stuff that seems pretty silly to me? Or do you think it's just smarter to go to a different tire shop to get my tires fitted, if it isn't all that dangerous after all?! Or to not widen my steelies more than half an inch?...
I really need help with this, I really like the stretched look, and I think Suj here has/had stretched tires aswell, so I assume he has some experience with it? I think I can trust you guys a bit more than my boss as I assume my boss has never stretched tires before...
M1KEH
M1KE
Oct 27, 2007
2,336
The Middle
An inch stretch will be fine. Whether you need to use fire etc depends on how good your compressor is. But I would say you'll probably be ok.
Mythbuster
352
Well no, they're not exactly low profile... 185/60 :p So effectively, 90% of the people, which are pretty much all of those with experience with these kind of tires say they're not dangerous, and 10% of the people, which are all of the people who don't, said they are super dangerous :p I think I can see a pattern there... Thanks guys! :)
abhardwaj1990
Yes, I'm licking my hand
Mar 16, 2009
3,434
Shottingham
Well to give you a bit of an idea, this is a 195/50/15 on a 7j
Mythbuster
352
Seems good enough for me. Think that's gonna look pretty sweet then, as mine are 185/60... But yeah, I'm just gonna assume you guys are right as you have experience with this, and the tire guy is.. well.. wrong really :p
What car are those originally from by the way? They look like they came of the E30 but I saw you also tried them on the Ibiza? They look nice! :)
Brummy
Nazi Moderator-Bot
Mar 6, 2005
4,275
Moved to the DarkSide
**...Post copied across from my Readers Ride Thread... **
Those tyres are as you see in the one pic 165 50 15s on a 7 wide rim so it depends of the set up you want really.
We haz a leeetle poke... we haz a leetle streeeetch.. we haz a leetle polish ,
et, Viola!!.......
Mythbuster
352
Those look Ace Brummy :p They really, really do... I'll just stick with my 185 tires for cheapz to be honest, 165 seems a little too much of the good stuff for me, might do it later though :p
Did you have to use like a bicycle inner tube thingy to get the tire on, or was it just a case of filling it up with air and it beaded without help?
Brummy
Nazi Moderator-Bot
Mar 6, 2005
4,275
fat bloke and a lot of persuasion ! ;)
those rims have only covered about 12 miles on the car so are all wrapped up again and the tryes are all but brand new !
Brummy
Nazi Moderator-Bot
Mar 6, 2005
4,275
Werent 100% on actually getting to Inters Bloke, and tbh, dunno if they'll actually grace the mk2 as its pretty much season over show wise for me. i'll not be at Ed as Ive been roped into a suprise b/day pressie for a mate that weekend (playing with steam trains of all things) and ive already said that the green hornet may well be leaving me at some point this year.
