Squeeky Outside!!!
helms
Console Race Car Driver
Jan 30, 2005
492
Basingstoke
Yes thats right ladies and gents, my car is squeeking on the outside. [:@]
Presume its the suspension, its kind of an annoying metal on metal queek. [:@]
Anyone else had this, any one know how to get rid of it?
Ive got Konig Coil overs (or what ever they were called)
Thanks chaps.
Andy,
helms
Jan 30, 2005
492
Basingstoke
mine only squeeks when i got over a small bump.
Driving through a car park with speed bumps for example, it will squeek on the compression after going over...
Ill have to live with it for the time being i guess, never mind.
RichN
Collecting Rings
Jan 29, 2005
533
Oxford
www.Oxford7s.net
wheel bearing? my car squeeks but it stops when I apply the brakes, even very slightly, so thats obviously something to do with my brakes!
Quite often a lip develops where the disc is greater area than the pad covers. Get it filed down or replace disc if it's nearly done.. I got this after 6k miles on new discs and pads, and just had it removed, all sorted.
Also got it when i replaced pads but not discs, after the pads took on the shape of the slightly worn disc. Again, had the lip filed and squeaky gone-y.
kieran_cupra
Yellow n Black works!!!!
Apr 15, 2006
403
Nottingham
you what? so every single metal on metal squeek coming from a car is 100% the intercooler pipe bracket?
Well seeing as that used to be my car and i know exactly what the noise is , it think you will see that im right!!!!
I know its not the wheel bearings as these were done 12 months ago and the discs asnd pads around 13 months
