Welcome to our new sponsor Lecatona, a brand dedicated to enhancing performance for VAG group sports cars, including SEAT, Audi, Volkswagen and Škoda. Specializing in High Pressure Fuel Pump (HPFP) upgrades.
Mine squeeks when I get out the car (with the handbrake applied) -- but like trucido, I think that's more a problem with my brakes than anything else. Getting new ones next month anyway, hopefully that'll sort it.
mine only squeeks when i got over a small bump.
Driving through a car park with speed bumps for example, it will squeek on the compression after going over...
Ill have to live with it for the time being i guess, never mind.
My brother had coilovers on his 214 back in the day, his weren't "seated" properly, every time he jacked the car up it would either cause the car to squeek or solve the problem... don't know if this is similar to your problem.
Quite often a lip develops where the disc is greater area than the pad covers. Get it filed down or replace disc if it's nearly done.. I got this after 6k miles on new discs and pads, and just had it removed, all sorted.
Also got it when i replaced pads but not discs, after the pads took on the shape of the slightly worn disc. Again, had the lip filed and squeaky gone-y.
