Sport Information Menu
jamierohman
16
Is the sport information menu only available in the Cupra? as i am wanting to get it on my 1.4Tsi 150 or is there a way to use Vagcom or anything else like that might be able to enable the menu?
Liam0161
61
Manchester
I would also like to know as I have a cupra 280 an have no sport menu.
Deleted member 103408
Based on what i have seen on the GOLF Forums and OBD11 This is not an option you can code (VCDS or OBD11) as its a software that has to be enabled by SEAT Dealer (and again I am sure they dont sell it in the aftermarket).
dieselface
647
Sure it was only installed from 2016 model year too? Not sure it is backwards compatible..
kiddo
ST Cupra
May 30, 2015
1,151
99
Lancashire
What options do you get if you press car > view (top left)
taneltag
7
TC button is standard for all Cupras. Sport Display came with infotainment system update (somwhere in 2015).
If you have 6,5 inch screen then most likely you have MIB2 system so you have sport info. But earlier versions had 5,6 inch screen and MIB1 system - cant have sport info.
Traction control switch is standard for all Cupra Leons.
kazand
Is powered by Medtronics
Jun 6, 2010
4,138
73
Brum
Not the case. Whilst TC on/off is indeed standard on Cupra's, on some there is no physical button but you have to access the on/off 'button' via the menu.
taneltag
7
Then I don't know. Mine is early 2014 cupra 280 and I have physical button for it and all other I've seen also had it.
JohnWB87
24
Midlands
I'd be lost without the TC button now I've gone DSG. :whistle:
Back to the sports display though, I didn't have it in my 2014 280 but do in the 300, and in my opinion it is interesting but a bit of a gimmick and more for a passenger. I tend to find that when I've driving "sportily" my attention is required elsewhere.
eltawater
Full and wholesome member
May 1, 2008
321
52
Sport and physical TCS button on my 2016 280. I don't ever bother with the sport menu, too busy driving :)
Sent from my XT1068 using Tapatalk
Mpike1984
I have top spec 2017 leon fr 1.4 ecotsi 150 with all extras and my infotainment doesn't give me the sports screen where you can see the turbo psi and geometry is there a reason why?? I don't have it and what do I need to do?
