Spacers
Mr OCD
1,974
Manchester, UK
The Pro Race will most likely use a tapered head bolt and the LCR wheels will use a radius so you'd need different bolt regardless but you could use the same actual spacers for each set. I'd go 15mm rear and 10mm front.
Damian @ DPM Performance
Surely for handling purposes they should be the same all round?
- looking at spacers myself.
GoogleBear
Van by Day....R by night
Nov 9, 2010
518
Caernarfon, North Wales
Yep that what I have at the moment, 2 sets of standard length bolts and lock nuts.
I was thinking if I stay with 3mm on front and 20mm bolt on at the rear I could get away with using the bolts/lock nuts I already have for both sets of wheels.
Not sure how that would handle though, I know you already recommended a 3mm / 12mm setup for me, which I'm still considering
Out of interest is the 20mm bolt on spacer any more or less safe then the bolt through type?
Br!dges
753
Wales
Where did you get them plates and what font are they, UK/GER etc?
Alan
Sorry for the late response buddy.
Got the plates off eBay, unsure who the seller is as I had them for my previous car. But basically the plates were made in the actual German factory where they do the normal German plates.
So I'd assume the writing is German & not uk buddy?!?
alcarp
No probs at all.
Yeah just had a look and found a seller who does everything the same as the german factorys do.
Upon further investigating they are deffos german font, I havnt seen any UK font pressed plates on cars so unsure what to get. You ever got any attention from the plod for them?
Br!dges
753
Wales
No attention what's so ever fella!
But saying that plod forces are different where ever you live!!
big eck
3,976
Falkirk, Scotland
No probs at all.
I had UK font pressed steel plates on mine mate. Got them from Dubmiester, they were legal as well with the BS standard stamp.
big eck
3,976
Falkirk, Scotland
Where's the best place to get decent but cheaper spacers??? There are a load on eBay but I'm not sure which ones are best.
Bridges yours is spot on. Where did you get yours and did it come with the bolts???
