Spacers??
ibizacupra
Jack-RIP my little Friend
Jul 25, 2001
31,333
19
glos.uk
DRUMS... ahhh - different thing.. Had Cupra in my mind with rear disks.. in which case yes you have to check your rear bolt length to not contact drum brake internals... click click click when turning the wheel or not able to turn it at all possible otherwise.
......and I do know how spacers and bolts work ;)
Mar 16, 2007
620
SouthWales
well these are the spacers ive got .. theyr from one of the boys near me with a Lime Ibiza Cupra soo he had new spacers and i had it old ones off him but they were onli on his car for a few weeks. These are them and i dont understand when u bolt the spacers to the hub then the wheel ontop ?
these ones you just put the bolt through the alloys/spacer into the hub i think ?
THANKS
Mar 16, 2007
620
SouthWales
yes mate ... soo could anyone kno the reason theres a slight nocking/clickin noise when i put the spacers on and its onli on the one side of the car ?
thanks
pdcupra
Ibiza-less
Aug 11, 2006
743
King's Lynn
i had this problem when i got mine. Got the kit second hand with the longer bolts, fitted and thought great, going down the road it kept clicking - it got worse and worse - to the point where a mate was following me and said my wheel looked buckled! Checked the bolts and they were loose, took the bolts out and realised the ones i got with the kit had a tapered seat (like the ones in your pics fcuknafe) and my old wheel bolts where the flat seated type, so i was running the complete wrong bolts! Got the proper style bolts - and no more clicking!
Adam R
Diesel ISN'T a Dirty word
Mar 5, 2007
2,851
lee in the solent
your very lucky your wheels did not fall off! i have seen people run with wrong wheel bolts and the heads off the bolts just shear off.
i think there is a good example of this on youtube where a car loses all 4 wheels!!!
Jan 8, 2007
2,958
Wiltshire
The idea of using separate bolts to connect the spacers to the hubs is to reduce the strain on the wheel bolts when you need to use a longer thread. Handling is improved but the pressure on these bolts in increased and so it's vital you use the correct type as stated above.
Mar 16, 2007
620
SouthWales
sooo basically i need a differnt set off bolts is that what ur sayin ? and i jacked the ibiza up this mornin turned the wheel with the spacer put back on and there was clickin had a look around and couldnt see anything. took the spacer off and but orignal bolts back in and nothin wrong. maybe i need to cut the longer spacer bolts down ? and how come its onli on one side
thanks
ibizacupra
Jul 25, 2001
31,333
19
glos.uk
Sorry but ya wrong dude.
Bolts CLAMP the wheels to the hub... so long as the spacers are hubcentric the wheel load goes through the hub spigot not the wheel bolts, as they are clamping, be they 25mm long or 50mm long.
Bolts should not be taking shear load, just tensile load from clamping
:thumbup:
Mar 16, 2007
620
SouthWales
well no! because ive just bought these 15mm which look wkd when theyr on. and mine are hubcentric arnt they because they fit into the alloys. I dont know what to do about the bolt situatuon hmmmm
Mar 16, 2007
620
SouthWales
hmmm good idea was actually thinkin off that myself. I know its a silly Q people does anyone know how much i need to take off ?
thanKs
