I have them ebay ones delta mics on mine 20mm rear spacers and have no problem what so ever, think there pretty good imo. Each to there own tho as ive found they do there job, were reasonably priced and vastly improved the handling.
impossible as i have the 20mm spacers which bolt to the hub and then your wheel bolts to the spacer. ITs impossible for the bolts holding the spacer to the hub to come off as the wheel sits flush ontop of the bolts therefore impossible for the bolts to turn and come slack. I think there was a problem with the 15mm ones as im sure i read afew threads about them before i got them.
I'm sure martyn, acidstrato and daz had them wobble off.
Hmm, well thats unlucky. Either i check my wheel nuts too often or i'm not driving hard enough. (plus that thread dosnt refer to MOMO spacers, but the same design i guess)
Various people have tried these to find they rattle loose. Not a good product at all
ive got these ones and they have been perfect!
when i first fitted them i took the wheels off every few days to check nothing was coming loose... all were fine
ive had them on for about 6 months now and had no problems at all
haha
its 42 or 43 mpg!
i have got that a few times now driving from Reading to Nottingham
it does mean driving like an absolute granny all the way up the M1 (like 60-70mph) but it does do it, and when i arrived i fiiled the tank back up and calculated the mpg from that and it was almost spot on!!
they can be economical, but mine is rarely over 32mpg through normal driving
