Hay all
I need help with a noise I've got that I'm worried about that sounds like a bearing of some sort
I've not had alot of dealings with bearings going on car but this does sound like one. It's definately not a wheel bearing as I've listened going around corners and theres no more noise when turning either way. I have had a bearing go on wheels before so definately not this.
The other thing that has been changed very recently is my Front discs and pads, the discs are EBC Ultimax with grooves. Is it possible that this could be causing the noise?
I have been running winter tyres for three ish months but it aint this either as it doesn't change when changing road surfaces.
I'm pretty sure its not the thrust bearing in the clutch as it only happens at 30 MPH+
What can people suggest that I can try to prove/dispove other bearings??
Is there a bearing in the turbo that might be on its way out?
I still need to test this but doesn't seem to make a noise when turbo isn't spinning at 30 MPH+
Any help would be greatly recieved
Cheers muchly
Cheers muchly
