While that was drying i set about stripping the engine
Fitting ARP Main Stud kit
Stripped Back
New gaskets to be fitted...
Bonded sump gasket
Oil pump to block
Front oil pump
Rear Main
Both cam seals
Gearbox drivershaft seals
Both gearbox sensors
Outside temp sensor
Outter CV boot
Rocker cover gasket
think thats about it...
For my reference really...
Bonded sump gasket part number
Sealer part number
Cleaning all threads out
Bottom end all back together
Onto the clutch and flywheel set up...
I did abit of weighing of SBS lightened pot style flywheel which was around 5-6kg and the TTV flywheel measured 4.5kg, so a slight difference. (Weights are rough...) Just a little bit of info for people...
Onto fitting the TTV flywheel with ARP flywheel bolts
Stripped Back
Bonded sump gasket
Oil pump to block
Front oil pump
Rear Main
Both cam seals
Outside temp sensor
Outter CV boot
Rocker cover gasket
Sealer part number
