just run a couple of logs to see how cars adapting with the FMIC,and after a couple of tanks with the octane booster with the BP ultimate
CF's look better
fuel trim has gone from -10.9 to 0 is that good or has something broke/failed?
FMIC working well ,intake temps from 50 down to 27
Code:
Group A: '020 Group B: '032
Cylinder 1 Ignition Cylinder 2 Ignition Cylinder 3 Ignition Cylinder 4 Ignition Lambda (add.) Lambda (mult.)
TIME Angle Delay Angle Delay Angle Delay Angle Delay TIME Self-Adaptation Self-Adaptation
STAMP °KW °KW °KW °KW STAMP % %
0.3 0 0 0 0 0.01 0 0
0.91 0 0 0 0 0.6 0 0
1.51 0 0 0 0 1.21 0 0
2.11 0 0 0 0 1.81 0 0
2.72 0 0 0 3 2.42 0 0
3.32 0 0 0 3 3.02 0 0
3.92 0 0 0 3 3.63 0 0
4.53 0 0 0 3 4.23 0 0
5.13 0 0 0 3 4.84 0 0
5.73 0 0 0 3 5.43 0 0
6.35 0 0 0 3 6.05 0 0
6.94 0 0 0 2.3 6.65 0 0
7.55 3 3 0 5.3 7.24 0 0
8.15 3 3 0 5.3 7.86 0 0
8.75 3 3 0 5.3 8.45 0 0
9.36 2.3 2.3 0 5.3 9.05 0 0
9.97 2.3 2.3 0 4.5 9.66 0 0
10.56 2.3 2.3 0 4.5 10.27 0 0
11.16 2.3 1.5 0 4.5 10.86 0 0
11.78 1.5 1.5 0 3.8 11.48 0 0
12.38 1.5 1.5 0 3.8 12.08 0 0
12.99 1.5 1.5 0 3.8 12.67 0 0
13.59 0.8 0.8 0 3 13.29 0 0
14.19 0.8 0.8 0 3 13.88 0 0
14.8 0.8 0.8 0 3 14.48 0 0
15.4 0 0 0 3 15.1 0 0
16 0 0 0 2.3 15.7 0 0
16.61 0 0 0 2.3 16.3 0 0
17.21 0 0 0 2.3 16.91 0 0
17.81 0 0 0 2.3 17.51 0 0
CF's look better
Code:
Group A: '115 Group B: '118
Engine Speed Engine Load Charge Pressure Charge Pressure Engine Speed Intake Air Charge Pressure Charge Pressure
TIME (specified Value) (actual Value) TIME Temperature Solenoid Valve (actual Value)
STAMP /min % mbar mbar STAMP /min °C % mbar
0.57 2360 112.8 2050 1270 0.27 2320 23 95.3 1160
1.17 2480 142.1 2080 1570 0.87 2440 23 95.3 1420
1.78 2640 166.2 2080 1840 1.47 2560 23 95.3 1700
2.38 2800 191 2090 2120 2.08 2720 22 95.3 1970
2.98 3000 190.2 2090 2210 2.68 2920 22 83.5 2240
3.59 3160 178.9 2040 1980 3.29 3080 21 77.3 2030
4.19 3360 182 2000 2020 3.89 3280 21 78.8 1970
4.79 3520 175.9 1960 1970 4.49 3440 21 78 2020
5.4 3680 174.4 1990 1940 5.1 3600 21 78 1920
6 3880 174.4 2010 1950 5.7 3760 21 78.8 1970
6.61 4040 182 2020 2040 6.3 3960 22 82.4 2000
7.21 4200 181.2 2000 2000 6.9 4120 23 81.6 2070
7.81 4360 179.7 1980 1970 7.51 4280 23 82.4 1950
8.41 4520 175.9 1950 1940 8.11 4440 24 81.2 2010
9.02 4680 174.4 1930 1940 8.72 4600 24 81.6 1910
9.63 4840 172.2 1910 1910 9.33 4760 24 80.8 1940
10.23 5000 171.4 1890 1890 9.93 4920 24 82.4 1860
10.83 5120 172.9 1860 1890 10.53 5040 25 82.7 1930
11.43 5240 164.7 1840 1780 11.13 5200 26 79.2 1820
12.03 5400 171.4 1820 1800 11.73 5320 26 85.1 1830
12.64 5520 163.9 1790 1780 12.33 5440 27 82.4 1840
13.25 5640 163.9 1780 1730 12.94 5560 27 83.5 1760
13.84 5760 162.4 1770 1770 13.55 5680 27 85.5 1760
14.45 5880 157.9 1660 1730 14.15 5800 27 81.6 1740
15.06 5960 142.1 1630 1550 14.75 5920 27 74.1 1610
15.66 6040 146.6 1620 1620 15.36 6000 27 80 1580
16.27 6120 135.3 1600 1510 15.97 6080 27 71 1540
16.87 6200 136.1 1620 1530 16.57 6160 27 74.1 1490
17.48 6280 136.8 1610 1520 17.17 6240 27 73.7 1540
18.08 6360 134.6 1580 1530 17.78 6320 27 73.3 1520
18.68 6440 133.8 1570 1520 18.38 6400 27 73.3 1510
19.29 6520 130.1 1540 1510 18.98 6480 27 71.8 1510
19.89 6600 128.6 1540 1520 19.59 6560 27 71.4 1510
20.49 6680 126.3 1530 1480 20.19 6640 27 69.8 1470
