some more logs
Jul 29, 2006
723
cumbria
www.facebook.com
just run a couple of logs to see how cars adapting with the FMIC,and after a couple of tanks with the octane booster with the BP ultimate
Code:
Group A:	'020				Group B:	'032
	Cylinder 1 Ignition	Cylinder 2 Ignition	Cylinder 3 Ignition	Cylinder 4 Ignition		Lambda (add.)	Lambda (mult.)
TIME	Angle Delay	Angle Delay	Angle Delay	Angle Delay	TIME	Self-Adaptation	Self-Adaptation
STAMP	°KW	°KW	°KW	°KW	STAMP	 %	 %
0.3	0	0	0	0	0.01	0	0
0.91	0	0	0	0	0.6	0	0
1.51	0	0	0	0	1.21	0	0
2.11	0	0	0	0	1.81	0	0
2.72	0	0	0	3	2.42	0	0
3.32	0	0	0	3	3.02	0	0
3.92	0	0	0	3	3.63	0	0
4.53	0	0	0	3	4.23	0	0
5.13	0	0	0	3	4.84	0	0
5.73	0	0	0	3	5.43	0	0
6.35	0	0	0	3	6.05	0	0
6.94	0	0	0	2.3	6.65	0	0
7.55	3	3	0	5.3	7.24	0	0
8.15	3	3	0	5.3	7.86	0	0
8.75	3	3	0	5.3	8.45	0	0
9.36	2.3	2.3	0	5.3	9.05	0	0
9.97	2.3	2.3	0	4.5	9.66	0	0
10.56	2.3	2.3	0	4.5	10.27	0	0
11.16	2.3	1.5	0	4.5	10.86	0	0
11.78	1.5	1.5	0	3.8	11.48	0	0
12.38	1.5	1.5	0	3.8	12.08	0	0
12.99	1.5	1.5	0	3.8	12.67	0	0
13.59	0.8	0.8	0	3	13.29	0	0
14.19	0.8	0.8	0	3	13.88	0	0
14.8	0.8	0.8	0	3	14.48	0	0
15.4	0	0	0	3	15.1	0	0
16	0	0	0	2.3	15.7	0	0
16.61	0	0	0	2.3	16.3	0	0
17.21	0	0	0	2.3	16.91	0	0
17.81	0	0	0	2.3	17.51	0	0
CF's look better
fuel trim has gone from -10.9 to 0 is that good or has something broke/failed?
Code:
Group A:	'115				Group B:	'118
	Engine Speed	Engine Load	Charge Pressure	Charge Pressure		Engine Speed	Intake Air	Charge Pressure	Charge Pressure
TIME			(specified Value)	(actual Value)	TIME		Temperature	Solenoid Valve	(actual Value)
STAMP	 /min	 %	 mbar	 mbar	STAMP	 /min	°C	 %	 mbar
0.57	2360	112.8	2050	1270	0.27	2320	23	95.3	1160
1.17	2480	142.1	2080	1570	0.87	2440	23	95.3	1420
1.78	2640	166.2	2080	1840	1.47	2560	23	95.3	1700
2.38	2800	191	2090	2120	2.08	2720	22	95.3	1970
2.98	3000	190.2	2090	2210	2.68	2920	22	83.5	2240
3.59	3160	178.9	2040	1980	3.29	3080	21	77.3	2030
4.19	3360	182	2000	2020	3.89	3280	21	78.8	1970
4.79	3520	175.9	1960	1970	4.49	3440	21	78	2020
5.4	3680	174.4	1990	1940	5.1	3600	21	78	1920
6	3880	174.4	2010	1950	5.7	3760	21	78.8	1970
6.61	4040	182	2020	2040	6.3	3960	22	82.4	2000
7.21	4200	181.2	2000	2000	6.9	4120	23	81.6	2070
7.81	4360	179.7	1980	1970	7.51	4280	23	82.4	1950
8.41	4520	175.9	1950	1940	8.11	4440	24	81.2	2010
9.02	4680	174.4	1930	1940	8.72	4600	24	81.6	1910
9.63	4840	172.2	1910	1910	9.33	4760	24	80.8	1940
10.23	5000	171.4	1890	1890	9.93	4920	24	82.4	1860
10.83	5120	172.9	1860	1890	10.53	5040	25	82.7	1930
11.43	5240	164.7	1840	1780	11.13	5200	26	79.2	1820
12.03	5400	171.4	1820	1800	11.73	5320	26	85.1	1830
12.64	5520	163.9	1790	1780	12.33	5440	27	82.4	1840
13.25	5640	163.9	1780	1730	12.94	5560	27	83.5	1760
13.84	5760	162.4	1770	1770	13.55	5680	27	85.5	1760
14.45	5880	157.9	1660	1730	14.15	5800	27	81.6	1740
15.06	5960	142.1	1630	1550	14.75	5920	27	74.1	1610
15.66	6040	146.6	1620	1620	15.36	6000	27	80	1580
16.27	6120	135.3	1600	1510	15.97	6080	27	71	1540
16.87	6200	136.1	1620	1530	16.57	6160	27	74.1	1490
17.48	6280	136.8	1610	1520	17.17	6240	27	73.7	1540
18.08	6360	134.6	1580	1530	17.78	6320	27	73.3	1520
18.68	6440	133.8	1570	1520	18.38	6400	27	73.3	1510
19.29	6520	130.1	1540	1510	18.98	6480	27	71.8	1510
19.89	6600	128.6	1540	1520	19.59	6560	27	71.4	1510
20.49	6680	126.3	1530	1480	20.19	6640	27	69.8	1470
FMIC working well ,intake temps from 50 down to 27 :D
DPJ
Dec 13, 2004
7,996
NN Yorks / Salento
www.seatcupra.net
Looks better. :)
You have zeros in 032 because you've either reset your throttle body or cleared a fault code?
Best not to log blocks like 020 and 032 together because neither of them show rpm. (That's why I suggest 003 and 020 115 and 031 118 and 032. In each pair, the second block doesn't show rpm.
Jul 29, 2006
723
cumbria
www.facebook.com
Dave,thanks for that mate,had a run out to newcastle yesterday,and the car had a bit of stuttering,I am just waiting for all the bits to come for my leak tester,think there is a leak as when i plant the foot its then when it feels hesistant,off boost its fine,am i heading in the right direction or could this still be maf related?
Jul 29, 2006
723
cumbria
www.facebook.com
throttle body has been cleaned Dave,think I'm gonna get 4 new coil packs,are the hitachi bolt down ones the preferred choice?
If i could get hold of another MAF to try,should I see/feel instantly if stuttering has gone,what i mean is car doesnt need to get used to new maf?
DPJ
Dec 13, 2004
7,996
NN Yorks / Salento
www.seatcupra.net
Stuttering should go striaght away. How many miles have your coilpacks done?
Jul 29, 2006
723
cumbria
www.facebook.com
Done some logs this morning
Code:
Group A:	'003				Group B:	'020
	Engine Speed	Intake Air Mass	Throttle Drive	Ignition		Cylinder 1 Ignition	Cylinder 2 Ignition	Cylinder 3 Ignition	Cylinder 4 Ignition
TIME			Angle Sensor 1	Timing Angle	TIME	Angle Delay	Angle Delay	Angle Delay	Angle Delay	TIME
STAMP	 /min	 g/s	 %	 °ATDC	STAMP	°KW	°KW	°KW	°KW	STAMP
0.3	2440	64.08	98	13.5	0	0	1.5	0	0
0.9	2600	81.92	100	10.5	0.6	0	0.8	0	0
1.51	2760	98.28	99.2	9.8	1.21	0	0	0	0
2.11	2920	117.64	100	9.8	1.81	0	0	0	0
2.72	3120	102.86	99.6	9.8	2.41	0	0	0	0
3.32	3320	122.14	99.2	9	3.02	0	0	0	0
3.92	3520	114.39	100	9.8	3.62	0	0	0	0
4.53	3680	119.17	100	12	4.23	0	0	0	0
5.13	3840	127.67	100	9.8	4.83	0	0	0	0
5.73	4040	141.17	99.6	14.3	5.44	0	0	0	0
6.35	4200	143.03	100	10.5	6.04	0	3	0	3
6.94	4400	154.81	100	12	6.64	0	3	0	3
7.54	4560	152.17	100	12	7.24	0	3	0	3
8.16	4720	160.11	100	12	7.84	0	3	0	2.3
8.76	4880	153.19	100	15	8.46	0	5.3	0	2.3
9.35	5040	168.03	99.2	18	9.06	0	5.3	0	2.3
9.97	5200	167.33	100	14.3	9.66	0	5.3	0	2.3
10.57	5320	168.08	100	20.3	10.26	0	4.5	0	5.3
11.16	5480	171.61	100	17.3	10.87	0	4.5	0	5.3
11.78	5600	177.08	99.6	18.8	11.47	0	4.5	3	5.3
12.38	5720	177.31	100	18	12.08	0	4.5	3	4.5
12.97	5840	176.78	100	18	12.68	0	3.8	3	4.5
13.59	5960	179.58	100	18	13.29	0	3.8	3	4.5
14.18	6040	181.81	100	20.3	13.89	0	3.8	2.3	3.8
14.78	6160	180.69	99.6	21.8	14.49	0	3	2.3	3.8
15.4	6240	179.83	100	22.5	15.1	0	3	2.3	3.8
16	6320	180.39	100	22.5	15.69	0	3	2.3	3.8
16.6	6440	182.39	100	24	16.3	0	3	1.5	3
17.21	6480	184.42	100	21.8	16.91	0	3	1.5	3
17.81	6600	181.94	100	24.8	17.51	0	2.3	1.5	3
Code:
Group A:	'115				Group B:	'031
	Engine Speed	Engine Load	Charge Pressure	Charge Pressure		Lambda Sensor	Lambda Sensor
TIME			(specified Value)	(actual Value)	TIME	Current Value	Specified Value
0	2320	74.4	1060	1170	0.28	1	1
0.58	2400	120.3	2050	1310	0.88	0.922	1
1.18	2520	151.1	2060	1610	1.48	1.008	1
1.79	2680	175.2	2070	1880	2.09	0.961	0.953
2.39	2880	191.7	2070	2110	2.69	0.977	0.945
2.99	3040	188	2060	2070	3.29	0.93	0.945
3.6	3240	187.2	2010	2000	3.9	0.93	0.945
4.2	3400	178.2	1970	1950	4.5	0.93	0.945
4.8	3560	170.7	1960	1880	5.1	0.922	0.922
5.41	3720	169.9	1980	1860	5.71	0.922	0.922
6.01	3880	175.9	2000	1950	6.31	0.906	0.922
6.61	4040	182	2010	2000	6.93	0.914	0.922
7.22	4200	183.5	1990	1990	7.53	0.899	0.906
7.83	4360	179.7	1960	1960	8.12	0.891	0.906
8.43	4560	178.9	1930	1940	8.73	0.891	0.899
9.03	4680	172.9	1910	1890	9.33	0.875	0.883
9.64	4840	173.7	1890	1930	9.94	0.86	0.86
10.24	5000	175.9	1870	1900	10.54	0.821	0.828
10.84	5120	168.4	1850	1840	11.15	0.813	0.813
11.44	5240	169.9	1830	1800	11.74	0.797	0.813
12.04	5360	167.7	1800	1840	12.35	0.782	0.797
12.66	5480	162.4	1780	1770	12.95	0.805	0.805
13.25	5600	166.2	1770	1760	13.55	0.789	0.797
13.86	5720	164.7	1760	1770	14.16	0.774	0.789
14.47	5840	159.4	1750	1740	14.77	0.758	0.774
15.07	5960	157.9	1740	1740	15.37	0.758	0.782
15.68	6040	157.9	1730	1710	15.98	0.75	0.766
16.27	6160	154.9	1730	1700	16.58	0.75	0.758
16.87	6240	154.1	1720	1680	17.17	0.75	0.758
17.49	6320	150.4	1710	1700	17.79	0.75	0.75
18.09	6400	150.4	1710	1690	18.39	0.75	0.75
18.69	6480	148.9	1700	1710	18.98	0.75	0.75
19.3	6560	148.1	1690	1660	19.6	0.75	0.743
Code:
Group A:	'118				Group B:	'032
	Engine Speed	Intake Air	Charge Pressure	Charge Pressure		Lambda (add.)	Lambda (mult.)
TIME		Temperature	Solenoid Valve	(actual Value)	TIME	Self-Adaptation	Self-Adaptation
STAMP	 /min	°C	 %	 mbar	STAMP	 %	 %
0	2360	24	95.3	1350	0.3	3.2	-18.8
0.6	2480	23	95.3	1600	0.91	3.2	-18.8
1.21	2600	23	95.3	1850	1.51	3.2	-18.8
1.81	2760	23	88.6	2100	2.11	3.2	-18.8
2.41	3000	22	78	2140	2.72	3.2	-18.8
3.02	3160	21	82.7	2000	3.32	3.2	-18.8
3.62	3360	21	78	2010	3.92	3.2	-18.8
4.22	3520	21	77.6	1920	4.53	3.2	-18.8
4.83	3680	21	78.4	1900	5.13	3.2	-18.8
5.43	3880	21	80.4	1930	5.74	3.2	-18.8
6.05	4040	22	84.7	2010	6.34	3.2	-18.8
6.64	4200	23	81.6	2000	6.94	3.2	-18.8
7.24	4400	23	81.6	1970	7.54	3.2	-18.8
7.86	4560	24	81.2	1930	8.15	3.2	-18.8
8.45	4720	24	82.7	1910	8.75	3.2	-18.8
9.05	4880	24	81.2	1950	9.36	3.2	-18.8
9.66	5040	24	82.7	1840	9.96	3.2	-18.8
10.26	5200	24	82.7	1890	10.57	3.2	-18.8
10.87	5320	25	81.6	1810	11.17	3.2	-18.8
11.48	5480	26	83.5	1800	11.77	3.2	-18.8
12.08	5600	26	82	1750	12.38	3.2	-18.8
12.67	5720	26	84.7	1790	12.99	3.2	-18
13.28	5840	27	83.1	1790	13.58	3.2	-18
13.89	5920	27	83.5	1720	14.19	3.2	-18
14.49	6040	27	84.7	1730	14.79	3.2	-18
15.09	6160	27	84.7	1720	15.4	3.2	-18
15.7	6240	27	82.7	1740	16	3.2	-18
16.3	6320	27	83.1	1690	16.61	3.2	-18
16.9	6400	27	82	1700	17.21	3.2	-18
17.51	6480	27	80.4	1650	17.8	3.2	-18
18.11	6560	27	82.7	1650	18.42	3.2	-18
DPJ
Dec 13, 2004
7,996
NN Yorks / Salento
www.seatcupra.net
what's the usual life expectancy of a coilpack?
Somewhere around 30k - 35 k miles I reckon.
Something not right there. I don't like the way the Maf readings are fluctuating up and down as they climb up the range. The ecu is compensating hard for it running rich. Note at around 3500 - 3700 rpm actual is a bit off requested boost. I think I'd double my efforts to find a boost leak first.
