Sharan (Same Thing!) Leaking
LMJ
Previously CEY_CLS :-)
May 4, 2009
1,789
Bangor, North Wales
Thought I'd chance it and ask on here... :)
My dad's VW Sharan (2005 TDi SE) was parked on a slope the other day, (driver's side front being the lowest point) it was raining, next thing he came back into the car after a couple of hours, the driver's footwell was soaked!...
Door seems fine, checked around the pedals / bulkhead, seems fine as far's I'm concerned. Any ideas!?
Edit: Passenger side's dry, and all door seem water tight. :confused:
LMJ
May 4, 2009
1,789
Bangor, North Wales
I'm not sure, funny how you mention that actually, I've been burrowing around for the heater matrix etc. Worth taking off the wipers / scuttle panel to check the drainage holes etc?
m0rk
sarcasm comes free
27,787
33
Clanfield, UK
I was just thinking it's possible the Pollen filter isn't located right, and then would leak
Alhambraguy
65
front passenger side and its tucked right under
wouldnt have thought it was the pollen filter
LMJ
May 4, 2009
1,789
Bangor, North Wales
Any ideas? Blocked drainage holes? It seems to be ok on the flat, its just that time it was parked on a slope, and a fair amount came in! It's water logged lol :confused:
LMJ
May 4, 2009
1,789
Bangor, North Wales
Original windscreen since new. Has developed some slight surface rust between the roof / seals and top of windscreen... Might've rotted further underneath? Hmmm, but for a 6yr old car?!
90landrover
308
Rhondda,S Wales
you don't need to take off wipers or scuttle panel to check drainage holes - they are located just by the bonnet hinges. Because of the way the car was parked the water could have come in from anywhere and just settled in the drivers footwell as that was the lowest point. I have seen water come in through the bottom door seal (front corner ) when parked at strange angles and the doors are not the tightest fitting things at the top edges either.
LMJ
May 4, 2009
1,789
Bangor, North Wales
I'll have a look then mate! I know, the doors are riddled with seals, about 3-4 on each. And I was thinking that too, parked as it was, it could've come in any where!
