Seat Leon mk1 gearbox oil change
seatleon87
16
Hi, I'm trying to change the oil on a MK1 Leon, used 17mm hex on the side, is this the drain or fill bit? Confused where to empty and fill
Bluepower
75
27
Drain at the bottom, fill at the front(when the car is set at level, as soon as the fluid runs out the opening, it is filled to the required level)
Reactions: Chris Bartram
seatleon87
16
I can't find a hex 17mm at the bottom though, picture below of the bottom, can only find the one on the side where I've removed the bolt
Bluepower
75
27
Sorry, I assumed you had an 02J box, but apparently you have the old style box..
Check out this vid, starting from 3 minutes:
smutts
373
188
Get the new oil from VW / Seat..
These gearboxes are very fussy with their oil.
At least mine was.
Reactions: seatleon87
Bluepower
75
27
Just throw in the oil approved for this gearbox, the oil in the box is 20 years old, any fresh oil that meets the specs will be better then the old junk.
Any SEA 75w will do, meeting specs API GL-4/GL-5/MT-1
seatleon87
16
Aw ok fair enough l, I've bought Comma - MVMTF Plus 75W-80 Fully Synthetic Manual Transmission Gear Oil Fluid
smutts
373
188
I've got the recommend one from Halfords, what happened to yours then?
Used a gearbox oil from Gulf, that specifically listed my gearbox.
It snagged,, baulked, popped out of gear,
Just horrible.
Put the Dealer fluid in and absolutely sweet as could be.
I was really surprised as I usually put something of good quality in & never go the Dealer route for fluids.
This was about the only instance that Dealer won out.
Fuchs Sintofluid also worked perfectly.
Gearbox Oil TITAN SINTOFLUID FE SAE 75W
Gearbox oil TL 726 /Y g052171a2?
G-052-171-A2
Nam-uk
1,258
408
lancashire.
Just horrible.
G-052-171-A2
its probably that oil now as Fuchs have the vw contract it use tobe castrol
