Update:
My car is now with more power so.... i change a few parts:
* RPM limit now is 7350rpm because big turbo wants more rpm
* M mode on DQ200 is 100% manual so rpm goes to 7400rpm and bounce waiting for new gear.
* Launch control 2000rpm... is impossible something higher on daily tires. I have 140 Treadwear tires but thats not enough for this power.
* Supercharger works until 3620rpm to avoid turbo lag.
* Im still usign a F23T Mixed flow turbo withotut lag, peak boost 4400rpm.
* I have 4 Ethanol injectors on fuel rail (after intake manifold) + 5 gal tank on boot and AEM kit to control the injection on boost. Car is using regular fuel on idle and regular fuel + 100% ethanol on boost. This produce 65% fuel 90ron E10 (stock injectors) at high rpm and 35% ethanol E100 (4 aditional injectors) = E41 fuel daily use (41% ethanol and 59% regular fuel). I can go higher but im using this for daily use.
* I have only tested this here at 2600 meters above the sea on 1/4 mile and i have a 190.6km/h speed and wheel spin on first and second gear. Is impossible on street tires.
Next step is test this car on E85 fuel using Ethanol on fuel tank + 4 ethanol injectors on intake manifold. Im going to test this mode this week. And i have to test the power on dyno but i guess is 420-430bhp.
