ScottHmk4 - 1.2 Cupra replica (Now Sold)
Feb 28, 2008
3,990
Scotland
new problem. noticed a few das ago but now became more frequent. car is making a shudder like randomly while driving, feels like its going to stall but then just knocks back in, only happens for a split second then returns to normal. im due to go f**king mental with it
Jul 12, 2009
1,484
London
www.flickr.com
Dude, I have never known anybody have as much bad luck as you mate :( I really feel for you! Sorry though, have no idea what the new problem is, i'm sure some clever bod on here will help!
Feb 28, 2008
3,990
Scotland
Have you plugged it into VAGCOM? Not just for error codes, but to do some logging
only faults im gettin is intervention load management and something about motor flaps for the aircon, nothing unusual. i will be honest i dont know how to do logging. my brother is stumped, so am i!! think were gonna put the old injectors and coolent temp sensor back in, other ones didnt make a difference and came from a scrappies, so i dont trust them that much.
vroomtshh
4,222
Dreghorn, Scotland
Logging is pretty straightforward and should show up some faults. I've no idea how to read the logs but plenty people on here can.
What is the intervention load management fault related to? Never heard of that before.
I'd say you can discount the aircon flap one.
Do you know anyone else with the same engine? Try swapping your injectors and temp sensor for theirs for a week?
vroomtshh
4,222
Dreghorn, Scotland
COnnect everything up, and I'm just going from memory here - in the engine diagnostic section, theres an option to log. Down near the bottom left. You choose the blocks you want to log ( a quick search on here should tell you which ones), and then it does the logs, saves them and you post them on here to get opinions.
I think you probably want to log requested airflow against actual, and something to do with EGTs for your problem, but I'm sure someone can direct you better in that way
Feb 28, 2008
3,990
Scotland
just went to do some logs, as it idles in the runway as i set up the logging the car started doing that drop of power, then very very violent shuddering, re-scanned the engine. misfire in cylinder 1. COILPACK AGAIN!!!! just replaced a coil last week in cylinder 3
kidinspace
Service Desk Specialist
Dec 3, 2008
1,227
Glasgow, Scotland
www.flickr.com
Sounds like you have an electric issue of some kind... I would get it seen by an auto electrician,no way it should eat a coil pack that fast, there is something wrong there...
Was it a "new" coil pack you have put in?
.G.
vroomtshh
4,222
Dreghorn, Scotland
.G.
Its a different cylinder, and from what I hear going through coilpacks like that is extremely common. They tell you not to replace them one at a time
Feb 28, 2008
3,990
Scotland
.G.
we replaced coil 3 last time, this was coil 1, apparently common to go one after the other, lets hope 2 doesnt go soon, tht'll be anotherr £30
ur rite it wasnt the same one mate. common issue apparently
even in a diesel, you just fill it up and go again
you havent ran out of fuel in a diesel before then,i drive a diesel by day not good when you have to bleed an injector to release the air.
sorry to hear your luck is getting worse scott might be best to change the other two coilpacks together or change one and save for the other.
dont want your car running on two cylinders for too long or it could kill the cat or worse your head gasket.
