normal or HID's, does not matter which. ok ill give examples.
if you want to adjust your light level from inside the car (change it between I and III) using the roller thing under your light switch then with the twin lamps it aint possible because the wiring loom for that part is slightly different. so what you need to do is adjust the hight that you want your bulbs to sit at manually from the headlight itself (reflection off a wall is prob best way) once you have the hight adjusted your done!
now one other problem...which is not too bad...
say you have your lights on normal...driving down the road and your giving someone way out a junctionor somthing, so you flash them, well what will happen is when you flash your high beam (flash) will turn on and your low beam (normal) will turn off so it will switch between them quickly.
HOWEVER if you are driving and need to see more of road ahead of you and you keep your high beam (flash) on by pushing the stock at the side of the steering wheel forward, the high beam (flash) and low beam (normal) will both be on.
see you alot round the killie one way system wen am up there (not often)
must say a like this not a fan of the mk4 but yours is nice![]()
thanks bud means alot
i get the whole inside adjuster, as for the other thing mines is like that just now anyways with the hid i got in, if i switch to full beam just now it knocks off dipped beam and goes to a manky yellow full beam, i dont use full beams with xenons anyways, and as for flashing people thats not a problem i can just flick my headlight switch which i also do just now anyways, surely there is a solution to these problems thought, there will be some sort of re-wiring needed to fix, surely someone one hre has done it and got everything working.
too much?
vinyl has just arrived for the bottom bit, unsure on the colour but al go give it a bash just now, pics added soon.
ok so didnt go to plan, colour was way off but i tried it anyways, soo hard to vinyl wrap as it turns out, because it bends it just creases, so vinyl is binned, only other option is too quote painting in which im in process of doing. u guys think its worth gettin done?
