RVC reversing camera installed
yanivkoval
152
32
Update - this weekend I have rewired my RVC power connection. I have connected it to the fuse box positive After ignition and the “Parkpilot” message doesn’t show up anymore.
Special thank to Red ibiza for his input.
smiciklas
11
I bought a regular cheap ntsc camera from AliExpress for testing, prior to buying something expensive.
i suppose that you have MIB2 system.. where did you plug video cable?
do i need to buy?:
car-interface.com/vendita/en/reverse-camera-input-seat/882-seat-mediasystem-plus-mib-reverse-camera-input-interface.html?search_query=MIB2&results=12
yanivkoval
152
32
do i need to buy?:
Can you tell me what car are you talking about ? Model and year ?
yanivkoval
152
32
I think same as yours... Leon 2017 ST FR with 8" MIB2
Than you don’t have to buy this interface.
Did you read this thread from the beginning?
It contains all the information that is needed to install the RVC.
If you don’t understand something, I will help you :)
smiciklas
11
Ok, i read all thread.. and i think that i manage all out...
just one question..
"I have connected it to the fuse box positive After ignition and the “Parkpilot” message doesn’t show up anymore."
Please can you send picture of that?
-antero-
60
14
Estonia
Reactions: leonlad
-antero-
60
14
Estonia
i am pretty sure highline cameras need to be paramertized before they work properly you sure only vcds ?
Seller did parametrization and coding before sending it to me, then I used VCDS to make some changes for it to work correctly. Parametrization has to be made for VW, Škoda parametrization did not work for me.
Smithcd
49
Is the coding for the camera the same on OBDeleven pro? I had a look last night and couldn’t reference anything from the earlier screenshots of VCDS to anything on the OBDeleven long code screen
